Problems to install FUJIFILM X Acquire on Macbook PRO "Cannot start FUJIFILM X Acquire. Another camera control application software is running."
Gilson
Greetings from Brazil!
  I have 2 questions:
   1) I get the following error when I try to install FUJIFILM X Acquire on Macbook PRO running macOs Big Sur 11.4: "Cannot start FUJIFILM X Acquire. Another camera control application software is running."
   What can I do to be able to install?
   2) Am I going to be able to use my X-T30 to recording in 4K using "Streamlabs OBS Recording Software" after I install "FUJIFILM X Acquire"?
Since you are using a MacBook, applications that use the on-board camera like FaceTime does while running in the background, may be getting in the way.
This may help:
https://www.howtogeek.com/682516/mac-camera-not-working-heres-how-to-fix-it/
I do not use the program you listed in your second question, so I do not have an answer for that one.
This may help:
Thanks for your help. I tried everything on that page, even to run the command
sudo killall VDCAssistant;sudo killall AppleCameraAssistant
and nothing worked.
How could you guys, Mac Owners running the latest mac OS Big Sur in Intel based architecture install the "FUJIFILM X Acquire" software? Thanks.
    • I didn't use cascable... stayed with just the two fuji apps
    • Buttons Fn1 and Q stopped working
    • Hi everyone I have a problem while using my xpro3 and strobes, from a day to an other I started to have a black shade on the side of my ID photos so it's kind of problematic. It's like if the speed is to high except it happened even at 1/30s. And the shutter speed seems accurate with ambiant light so I'm a bit disturbed about all of this.   Anyone has an idea about that case ?
