X100f in camera Provia / Standard not close to LRC Provia / Standard (Purples)
By Blue Zurich · Posted
Have you had each in hand? Size of camera body, couples with your hands might make or break which one you go with. Personally I cannot use an X-TXX model far too small. Then there is balance considerations depending on what lenses you'll be using, certain models are a better match than others on smaller or larger bodies. -
By David Holland · Posted
The Jacobean House stands in the grounds of the much older Hay Castle at Hay-on-Wye. It's just been refurbished, at great cost. They did a good job, as I hope the image shows. X-T2, 50 mm XR lens.Welcome, dear visitor! As registered member you'd see an image here…
Or look at an XT-2? Should be cheaper, and was made in Japan, so the build quality may be better. -
I have an x-100T and an X-T2. Both bought 2nd-hand, both nice bits of kit.
