"L" bracket for XT-4
sharkman53
Hi Wayne, I have this 3 Legged Thing QR11 L Bracket which is an universal L-bracket. If I mount it with a little space (approx. 1cm) between the left hand side of the X-T4 and the bracket I can carefully rotate the screen to open or close it.
The bracket can also be mounted the other way, to the right hand side of the camera. This way you can have the screen in any position you like.
Henk
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
