focusing issues
daveat22
I have used a XT3 for several years and loved it but my XT4 I have fallen out of love with. It keeps jumping out of automatic focus, so the indicator in the top right corner changes constantly to manual focus. that means I have to check and change it back to auto focus every shot or miss that perfect moment. I had two horses galloping towards me this morning, took a few shots and they were all out of focus because it had changed to manual focus. I have run through the settings comparing it with the Xt3 and they seem to be the same, but it is not working the same. Any ideas would be welcome.
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
    • Not sure how to delete threads, but I figured out what was wrong. In short, I was partially misunderstanding the view-mode's function. Also, the "+LCD Image Display" part requires that you have the Image Disp. setting set to anything but Off. Then it will display your last image on the LCD. If it's off, it's behavior will be exactly like the plain Eye Sensor setting.
