Probleme after firmware updates
Hi All,
I'm new to the X-H1 so please forgive my ignorance if these are well known problems and fixes.
I updated to the latest firmware 2.12 last night and since then have run in to two issues that make the camera all but unusable, so any help or advice would be much appreciated.
(1) I'm using vintage Leica prime lenses, so manual focus using the EVF. The EVF sometimes shows the whole frame and sometimes zooms in on a part of the frame. When this happens it's great for manual focus but there seems to be no rhyme or reason to when/if it happens or which part of the frame will be selected. A half press on the shutter release and the EVF switches to the full frame. I did briefly think the zoom was in response to me blinking but now don't.
(2) Playback just doesn't work at all. Pressing the playback button brings up a random shot, usually the last shot taken. Twiddling the rear command dial occasionally results in random zooming into the image but as often as not nothing happens or there's a brief glitch of the rear display. The rear joy stick seems completely inactive. The gallery view of shots taken is completely inaccessible. Sometimes the camera will lock up which can be cleared by turning it off.
The camera previously had firmware 2.01 installed and didn't display these issues.
I've done a full reset to no avail and even thought about rolling back the firmware. Fuji don't seem to allow this, I'm still googling to try and find a way to roll back the firmware, so if anyone knows how to do this please let me know.
Apologies for my first post being a cry for help
  • 4 months later...
By default, the rear command dial rotates to zoom in and out of the selected image during playback.  Zooming all the way out goes from full image, to images taken that day, to all images.  The front command dial below the shutter button goes back and forth from picture to picture, you can scroll through all the pics on the card.
Using a manual lens while shooting, the rear command dial, when pushed, zooms in and turning it gives you smaller or larger zoomed in view.  Then the front command dial does third steps shutter speed, whereas the rear dial does this when not being used for zooming in on manual focus.  Seems a little confusing, there is probably a way to change it, but I don't know how.
Hope this helps.
Loading...
    • Fujifilm has a standalone raw converter program that turns your raw images into either jpeg or tiff files. It has quite a few tools, of course you can then import the jpeg or tiff files into image editors for further processing if you want. https://fujifilm-x.com/en-us/support/compatibility/software/raw-file-converter-ex-powered-by-silkypix/ https://fujifilm-x.com/en-us/support/download/software/raw-file-converter-ex-powered-by-silkypix/
    • What do you thing to add your work on Wikipedia ? i stat some day ago something similar on https://en.wikipedia.org/wiki/Fujifilm_X-mount#:~:text=Pro%3B 26 mm-,Third Party X mount lenses comparizon,-[48][edit]
    • I am using a Fuji xt30. When I go into the Q menu I can alter the choices, for example to change the ISO, using the touch screen. However, when I try to do this with the rear command dial, it does not toggle between the options. How do I reset or get the rear command dial to do this? thanks  Ravenstonedale
    • Hey Folks- new Fujifilm XE-4 owner looking to upgrade my photo editing skills by using the RAW files to produce a final product rather than the jpegs.  Unfortunately my iMac Photos does not support the RAW files from the E-4.  I just learned that even the most recent version of the iMac iOS system (Big Sur) doesn't support the XE-4 RAW images.  So I'm seeking input on a photo editor that runs on an older iMac (2012 year model w/ 8 mgs of RAM, Intell Core i5 processor and plenty of hard drive storage) that does support Fujifilm XE-4 RAW images.  I am not a professional photographer, just an amateur looking to upgrade his skill and craft.  TIA for suggestions and advice.
    • Left Olympus this week New X-T3, 16-55, 50-230xc, 50 2.0 even trade for My Olympus Gear. Previously Shot with Fuji X-T1. Exited and looking forward to shooting and editing new Images.
