I have an XT2 and the body firmware version is 1.35... I've downloaded the latest firmware 4.40 for XT2
but there was an error "THIS FIRMWARE IS NOT FOR THIS MODEL. TURN OFF THE CAMERA"
I've tried different regions too.. but the error is still the same.
Does anybody experience this issue?
Is it possible for me to update this on my own?
Yes... Im sure that I've DL the XT2 firmware FWUP0010.DAT file name..
I've also tried multiple older versions from 1.10 / 1.12 /1.20 / 2.00 / 3.00 / 4.00 / 4.01/ and the latest 4.40
The SD card is formated using the camera or PC.... and still not working
still saying the same error massage....
I've also tried different regions for the 4.40 (latest) firmware...
still the same error message...
I just don't know what to do with this... :(
The SD card is freshly formatted in camera then put in the pc then transfer the firmware file.
There is no other files on the card...
I'm just guessing that maybe it's bcoz of the Beta 1.35 firmware?
It was not on the list of Firmware in fuji website... Maybe it's file name is different or something kind of special instructions?
Hahah.. It's just me...
I've also tried factory reset then instal the firmware update but still having the same isuue...
I don't know what can I do with this...
BTW thank you for replying Sir :)
Have you tried an other SD card?
Loading...
    • Welcome to our forum!
    • Hi Chris, I've had the same experience with my 15mm 4.5f Voigtlander. VERY soft images outside the center, moved on to the Fujinon 18mm 2f and perfectly happy. Cheers,
    • mornin' every one,  New to the forum and the X system. Camera collector since the '90s. I've been swapping old "analogic" stuff for "old" digital stuff. So I ended up with a X-T1 and a X-Pro1, with 27mm and 18mm (small ) and a few adapters to play with the Legacy lenses. Still adapting to the mirrorless ecosystem 😞 Meh...!
    • I am thinking of adapting my sigma 17-50 f2.8 canon ef-s lens on Fuji xt3 via a viltrox speed booster. My biggest confusion is that will this effect focal length and light gathering of my lens?  An speed booster does so when adapting full frame lens on APS-C bodies. But what if I want to adapt an APS-C Lens on another APS-C body via an speed booster?
    • Hi Jozzef, same with my one. The pictures at 16mm are not as sharp, as they should be. I given the lens back. Others say it is a good universal lens. Maybe some has problems from production side?
