Damaged X100V...
Thanks for the input. Maybe I'll have to rent one to try again.
HI Rufo, I have changed procedures. I now use the colors space transform (CST) as my first node. The CST is set up as follows: - Apply the CST effect to the first node. - Color Space is Rec 2020 - Input gamma is FLog - Output color space is Rec 709 - Output gamma is Gamma 2.4 All other nodes to grade the clip proceed the node that contains the color space transform. Hope this helps. Don
Ohio River, Kentucky - Indiana, USA Ohio River, indiana - Kentucky, USA -
By Astigmatism · Posted
Interesting, and a bit subtle. I also think it'd be better to activate on a half press. But there seems to be good reasoning behind a number of other choices, so I wonder if there's a good reason behind this one and we're just not seeing it. To some degree IS goes on and off like AF does, but this is an exception, isn't it? -
By Heccie Thump · Posted
I couldn't find my manual so downloaded a PDF copy and did some searching. From p146 of the manual, regarding Shooting Only stabilisation: "Image stabilization enabled only when the shutter button is pressed halfway (focus mode C) or the shutter is released." So it appears that the camera is 'working as intended' and that in AF-S the stabilisation mechanism kicks in only as you release the shutter. I think I would prefer it to activate on a half press, like it does in AF-C.
