Advice on Menu Settings for Landscape shooting?
Hey guys, The shutter on/off button switch may be loose on mine. After turning camera on and pressing the shutter/holding close to the area, the camera will turn off and say 'sensor cleaning'. This doesn't happen if I'm shooting via touch screen at all. Everything else is functional. Anyone else experience this before? Would love a much cheaper fix since Fuji Canada just quoted me $700 CAD to fix it, and considering everything else is functional except that part I'm not even sure why MPMB Main Board parts is being replaced😕 I got no explanation from them either.
