By teplosvet
Greetings,
Starting with a Nikon D750 + Sigma 50mm f/1.4 i recently moved to Fujifilm X-T4 + Fujinon 23mm f/2.
I started photography to cope with my bipolar disorder and big depression which i had my whole life. In the beginning i photographed all my friends, tried to find myself in portrait niche, but quickly understood that i just cant take pictures as they want me to. And i do not use photoshop or lightroom, i am not a fan of retouch. I mastered Capture One at some point, but now i do not see any use of it, as Fuji cameras already have everything needed inside of them. After all, i do not position myself as a photographer or retoucher, its just a hobby, and i try to catch things as my damaged head sees them. For example, here is a portrait of my mother, which was just a test shot:
Things now changed as i am currently working as an activity manager at a center where people with special needs live. People who live here are the most kind, honest and charismatic people i have ever met. I decided that i will try to spread their joy with the help of my hobby, and my employer was instantly hyped with the idea (god bless this woman). Here are some of the first pictures taken, thanks to Alexander who was happy to model:
If you are Interested in things i share, you can check my instagram at @dom.teplosvet
So, i guess that will be all for now from me.
Stay kind and spread joy, fellow photographers!
By teplosvet
Greetings everybody,
I searched multiple forums on the following topic, but did not get any close to solving the question explained below.
So, what i am trying to understand is this: why Q menu changes saved Custom Settings permanently?
i have my custom C1 settings set to be for example "noir 50's" style, i love it, it works for me, but time to time i want to tweak highlights/shadows for a step, but do not want to change C1 settings permanently. So, i shoot on a tweaked C1 settings, change to my C2 settings and assume that C1 settings goes to saved values. But somehow tweaking settings from Q menu overwrites my saved custom settings. So, is it a bug or a feature?
i understand that Q menu is just a shortcut to the listed settings, hence the name Quick Menu. But i do save my C settings for a reason, do i?
i thought that those C1-C7 things where supposed to be like a "shortcut to the shortcut" things, and changing them from one to another pulls according settings to the saved values, but i guess i am wrong?
By lamps br
I just bought a fuji x-t4, and since it's my first fuji camera I'm still lost in the menus. I found the option where I can set if I want it to focus before shooting or shoot right away: It's called RELEASE/FOCUS PRIORITY and can be found in the AF/MF menu. Here's a reference: http://fujifilm-dsc.com/en/manual/x-t3/menu_shooting/af_mf_setting/index.html
Now how can I use a shortcut to quickly change it? I'm used to shoot a nikon camera where I've set up a shortcut to toggle this option when a "fn" button is pressed.
By Psetel
I have a serious criticism of the X-T4 design: my Gitzo Traveler quick release plate - the smallest they make - blocks the battery door from opening fully while attached to the camera. The hinge for the door is too close to the tripod//quick release hole and the plate overlaps the hinge just enough to block it from fully opening.
The result is that I cannot remove or change my battery without removing the camera from the tripod and the quick release plate from the camera. What a pain!
Does anyone know of a Gitzo tripod head system compatible with the Traveler model tripod and that has a narrower plate where this won't be a problem?
Thanks!
By robgillman
Has anyone tried to adapt a Canon TS-E lens to any Fuji body? I'm specifically thinking about getting the 17mm for my X-T4, however I'm still weighing up the cost against the diminishing returns.
In general, how viable is adapting full-frame tilt-shift onto APS-C bodies? As far as I understand, on top of the focal length being increased by the crop factor, the shift range is also reduced by the same factor. So in the case of the 17mm, I would technically only have a maximum shift of 7-8mm. Is this correct? If so, is that still enough for a moderate amount of in-camera correction? I'm not expecting to capture a skyscraper from the across the street, but something that will cover the majority of cases.
Finally, are there any alternative solutions I should consider?
It's not cheaper when buying in Germany. Below are screenshots from the Leica store in Berlin Germany and from B&H , USA. I put the two cameras in the cart just for comparison sake. At today's exchange rate, 14050 Euros = $16720, which makes it more expensive to buy in Germany.
For limited numbers of images (up to 100k or so), the Lightroom or Capture One Catalogue usually will do. If you work in projects -like I usually do- Capture One Sessions is a much better option. I can also recommend the DAM (Digital Asset Management) of ON1 Photo Raw as it keeps raw and jpegs nicely together when you cull them. For large numbers of images Photo Mechanic is by far the best. It's often used by journalists and other pro's who have to search for certain images based on content. Either way, it's good to setup a file/directory structure on your PC/Mac that has some kind of system. E.g. per year/month/topic... before you load the images into a catalogue. And don't forget to backup...
Leica is 'victim' of the US trade taxes imposed on German products. Here in Switzerland Leica prices are a lot more agreeable. There isn't a day that goes by when I don't cherish my Q2 Monochrome. The 'victim' of that -unfortunately- is my X-Pro2...
