10-24mm WR + 16-55mm vs 10-24mm WR + 50-140mm?
A bit on the fence about my plans to clean house and switch up my lens configuration. Recently purchased the 16-55mm while it was on sale. I've used the lens in the past on travel shoots and if I was forced to own a single lens, this would probably be it.
But I would really like to add the new 10-24mm WR to my setup, as I'm now focusing more on travel and landscape photography. To that end, I'm feeling a bit torn. I know for sure I'll go with the 10-24, but it makes the 16-55 seem somewhat redundant with much of the range covered by the 10-24.
I'm considering whether I'd be better off selling the 16-55 and getting the 50-140mm, which I've used and know to be excellent for longer range, abstract photos when it comes to landscapes and travel.
Right now, I'm not sure I'm in a position to own all three, just can't decide between keeping the 16-55mm or just going for the more extreme ends of the spectrum with the 10-24 + 50-140. Thoughts? Thanks!
Edited by deepsun
7 hours ago, binfch said:
Why (replacing the 16-55) not buy a prime 35 or 50 or 60 and then add the new to be released 70-300?
Thanks for the suggestion. I should have mentioned, but I’m actually getting rid of a few primes in favor of the zooms. I use two bodies so I plan to have the 10-24 and either the 16-55 or 50-140. Ideally, I’d keep the 16-55 because just walking around it’s a great lens.
I also thought of the 55-200 as an alternative to the 50-140, but I see lots of conflicting opinions on sharpness and IQ.
Loading...
    • Nice. Which one was taken with X100F?
    • Father and Sons in Yellow Shirts - Dhaka, Bangladesh Fujifilm X-T3 - XF18-55mm f2.8-4 R LM OIS - Fujifilm Classic Negative Color Film Sim
    • I can confirm this. My X100V had the same as do some of my other XF WR lenses. The fact that some lenses do and others don't (same lens) leads me to believe that Fuji has quite wide production tolerances. Over the past 7 years I've had (partly still have) 13 different XF lenses. 4 of them needed replacement due to production failures (loose aperture or focus rings, crooked mount...). Though I really like Fuji cameras, to me that is a bit too often...
    • It's quite a difference. As a basis the Leica Q2 already has a very good 47Mp full-frame sensor paired with one of the best lenses ever made (a 28mm Summilux). By leaving out the color array filter on the sensor and optimizing the sensor lenses for monochrome images, you get an incredibly sharp and contrast rich monochrome image. Without the color array filter you also boost the low light performance and expand the dynamic range of the sensor by approx. 2 stops. In the meanwhile, I couldn't resist and purchased a Q2 Monochrome. I'm not disappointed. Though my X-Pro produces very nice Acros files, the Q2 Monochrome is a different league (also in price to be fair). I usually shoot monochrome for my personal work, but to be able to shoot at ISO25000 and have files as clean as an X-Pro at ISO1600 is amazing. At normal ISO levels, the level of detail and the tonality of the Q2 files is stunning. Both for the jpegs out-of-camera and the DNG raw files via Capture One.
    • I use Blender, it's an open source program, free to use and many good tutorials on YouTube. The program is also used by professional moviemakers. It does the same or more as the apps recommended above. link to Blender Edit: Davinci Resolve is another free video editor worth trying.
