I purchased a cheap remote flash trigger and a flash from Amazon. I also got a white umbrella. I mounted the flash behind the umbrella and put the exposure to -2 (to compensate for the flash because its not TTL). All my photos came out like this
I can 100% assure you that there was no vertical divider in the room.
Why did half the photograph go completely dark?
Loading...
    • Father and Sons in Yellow Shirts - Dhaka, Bangladesh Fujifilm X-T3 - XF18-55mm f2.8-4 R LM OIS - Fujifilm Classic Negative Color Film Sim
    • I can confirm this. My X100V had the same as do some of my other XF WR lenses. The fact that some lenses do and others don't (same lens) leads me to believe that Fuji has quite wide production tolerances. Over the past 7 years I've had (partly still have) 13 different XF lenses. 4 of them needed replacement due to production failures (loose aperture or focus rings, crooked mount...). Though I really like Fuji cameras, to me that is a bit too often...
    • It's quite a difference. As a basis the Leica Q2 already has a very good 47Mp full-frame sensor paired with one of the best lenses ever made (a 28mm Summilux). By leaving out the color array filter on the sensor and optimizing the sensor lenses for monochrome images, you get an incredibly sharp and contrast rich monochrome image. Without the color array filter you also boost the low light performance and expand the dynamic range of the sensor by approx. 2 stops. In the meanwhile, I couldn't resist and purchased a Q2 Monochrome. I'm not disappointed. Though my X-Pro produces very nice Acros files, the Q2 Monochrome is a different league (also in price to be fair). I usually shoot monochrome for my personal work, but to be able to shoot at ISO25000 and have files as clean as an X-Pro at ISO1600 is amazing. At normal ISO levels, the level of detail and the tonality of the Q2 files is stunning. Both for the jpegs out-of-camera and the DNG raw files via Capture One.
    • I use Blender, it's an open source program, free to use and many good tutorials on YouTube. The program is also used by professional moviemakers. It does the same or more as the apps recommended above. link to Blender Edit: Davinci Resolve is another free video editor worth trying.
    • When using a cable make sure that USB mode is et correctly in your set up menu: http://fujifilm-dsc.com/en-int/manual/x-t200/menu_setup/connection_setting/index.html#usb_mode
