XT4 Firmware
colhot
 Share
Fix the autofocus in video.  Thomas Heaton (landscape photographer/blogger) commented when he reviewed the camera that they ought to sell it with a Bow and Arrow because it likes to Hunt (he likes the camera otherwise).  For stills it's pretty good but for video it keeps doing this thing where it loses faith in its own ability and suddenly rechecks focus by tuning out and back.  On some lenses (Viltrox 33mm) it makes it virtually unusable
Look trough Pal2tech videos on Youtube, on X-T4 and some other videos he has also. He mention some buggs in X-T4 that should be corrected. I think they should offer an OLED display instead of the outdated LCD (stone age...), regarding hardware side. As enhancements via firmware other then fixing the kown bugs I can not think of anything right now but maybe some feature could be moved over from Fujifilm high end cameras to X-T4 also (it is on the edge to a high end camera, for me at least, I have X-T4).
I guess IBIS can be improved even more, can not hurt. But IBIS is probably very good already.
/Bo
Edited by bem
Loading...
 Share
    • Hercules Cluster M13 (84 minute equivalent exposure). From a dark place, you can see this one in the northern sky just by looking up. Of course, having more than 100,000 stars in the cluster helps brighten it up a bit. https://www.messier-objects.com/messier-13-hercules-globular-cluster/ https://earthsky.org/clusters-nebulae-galaxies/m13-finest-globular-cluster-in-northern-skies/ https://science.nasa.gov/m13-great-globular-cluster-hercules
    • I am guessing you do not have another lens? Can you rent or borrow one from your local camera store?
    • Gentlemen, I suggest you not to use bell collars. Let's imagine every time you move you have this "ding ding" in your ears.
    • Must be the firmware. I have this lens and the 33, which are great btw, and had a problem with the latter. I tried to update to the latest version, the problem is there are two, a white silk screen and a golden something. Once the updated was done, the lens started to focus continously. I deleted all the updates and installed one of the two, I don't remember which one. Then the lens worked perfectly. The problem is the Viltrox customer care doesn't exist. I tried to contact them to know the difference between the two updates, but nobody ever replied.
    • When I used the 50r for a couple of years I used my 2012 iMac 27" with 1TB HD, and 16GB of Ram as well as my 2014 MacBook Air with 8G of Ram and 256G HD Was it the best?  For me it was.  I shoot both JPEG & RAW at all times - and the files loaded fast enough.  The most I ever loaded at one time was over 9,000 files after a month in Colorado.  Does it take some time? YES.  But since I'm not a run and gun guy and am retired and don't do weddings or events any more I don't mind the wait as I have other things to do. Now that I have the 100s those machines listed above just CHOKE.  They do work, but you need the patience of a saint plus don't even think about doing HDR/photo merges, etc.  Not happening.  Since I bought my 100s I've switched to a 2020 iMac 27"  5k retina with 16G of RAM.  I find the 100s files quite zippy - and I"m talking about the raw files as after I review the jpegs to decide what I want to keep/edit I chuck most of them.  My iMac is a intel I-core 5 which at the time was the basic model available.  Initially I bought it for my spouse to do her work on which is why I did not get more ram.  Had I known I would move my work flow to her iMac I would maybe have purchased more memory.  But, so far, I've done the 400MP stitching, photo merges, etc in LR and Photoshop, and I use Capture One for my post-processing and I am extremely happy. Another item which I started using at the beginning of the year for the 50r and the 100s files is my iPad Pro.  I find that device to be a beautiful piece of equipment that I use both at home and on the road.  It's smooth, great and true color reproduction and FAST on JPEG's and RAW.  Since I only have the 512G version I use USBC Samsung Externals when needed.   In a four weeks I'm headed to Alaska and the Arctic for two months to shoot travel and stock.  I'm not taking my laptop - only my iPad Pro.  I love working on it and have developed a workflow that works for me.  I'm packing two Samsung T5 SSD 1TB externals, plus two Lacie Rugged 1TB externals for storage and backup.  If I need additional storage I can pickup another external pretty much anywhere until I go to the more remote locations. Hope that helps.
