Hi,
I had a quick search for this and couldn’t see anything so apologies if it’s been posted before.
I have an X-T30 which I love, but the one thing that annoys me is the tripod plate needs to be removed to access the battery compartment. I’ve seen a few l brackets which allow access to the battery compartment.
I have a Peak Design tripod, so the plate needs to be unscrewed with a little key and it’s just a pain.
Can anyone recommend an l bracket which is compatible with the X-T30, allows access to the battery compartment, is decent quality and doesn’t add too much bulk?
I’d appreciate it if you could send your recommendations.
Thank you 😊
Share this post
It depends on your budget, (like everything else I suppose :) ).
Really Right Stuff makes a l plate which is pretty good but does not, for some reason, have the grip piece: https://www.adorama.com/rrsbxt30lset.html
Fotga makes a decent one that does include the grip piece and is lower in price, but for some reason has only been selling via eBay -- you have to import it rom China now.
Both of these companies sell true l-brackets (arca style) that you can mount in either portrait or landscape mode, you are able to get the node point correct for panorama shots. And you are able to get to the battery as well as the USB ports etc. while the plate is on the camera.
Keep in mind if you find l brackets for the X-T10 or X-T20, these will also work for the X-T30 because the base is the same on all of the bodies.
Edited by jerryy
Share this post
Hi Jerry,
Thanks for your helpful reply! I’ll check these out. I’m happy to spend a little more if it’s good quality.
Im not buying an L plate for the extra grip but just to make it easier to use with my tripod so I don’t have to screw and unscrew the plate all the time.
Share this post
Loading...
    • By StudioB|Photography
      I switched over to Fuji from Nikon a few years ago and seem to have become quite a gear collector. When I used Nikon I had a Nikon D7200 and the 24mm f1.8, 35mm f1.8, 50mm 1.8, 85mm f1.8, and 60mm f2.8D lenses. Since moving to Fuji I have managed to obtain the following:
      cameras: X-T3, X-T30, and recently the X100V
      lenses: Laowa 9mm f2.8, Fuji 10-24mm, Fuji 16mm F2, Fuji 16mm f1.4, Fuji 16-80, Fuji 18-55, Fuji 23mm f2, Fuji 27mm, Fuji 35mm f2, Mitakon 35mm, Fuji 50mm F2, Fuji 56mm, Voigtlander 58mm f1.4, Fuji 55-200, and the Fuji 90mm (still also have the Nikon 60mm f2.8D).
      So I love all of these lenses, but honestly have way too many to put them all to use as I should. I am wanting to move to a minimalist set up. I recently purchased the X100V and instantly fell in love with that camera. The one lens design has really helped me rediscover what I loved about photography upon first starting out. So the X100V is staying with me. So I am wanting to sell some of my excess and need some advice about what to keep. At the moment I am thinking about keeping the X-T3 with the Laowa 9mm, Fuji 16 f1.4, Fuji 56 f1.2, Fuji 90mm f2, Fuji 16-80mm, Mitakon 35mm, and Voigtlander 58mm f1.4 (just for the fun of manual focusing).
      My question is, does this sound like a reasonable set-up? I really want to move away from zooms (except for the 16-80 for fun).
    • By Somemorr
      My problem:
      My X-t30 no longer lets me record video. Nothing happens when I push the shutter button in video mode.
      Background:
      - My main use for this camera is for recording video projects at my workplace.
      - I noticed the issue after using the camera as a webcam with a elgato camlink 4k. I had optimised the in-camera settings for use as a webcam during the past months of Zooming everyday.
      My attempted fixes so far:
      - I reverted all my in-camera settings back to my usual, non-webcam settings.
      - I updated the firmware to the latest version.
      -  Many google searches to see if anyone else has had and posted a fix to this issue.
    • By m k
      The photo editor Darktable have added support for X-T30, however that support currently lacks a noise profile. It would be great if someone would be able to assist them by creating one for them. There are instructions on how to create such a noise profile here https://pixls.us/articles/how-to-create-camera-noise-profiles-for-darktable/
      I do not have all the pre-requisites for the photo-part of the process, but I can assist with the non-photo parts of the process if needed.
    • By Snuggarelli
      I recently picked up the x-t30 after finding the Sony X100 Mark 7 point and shoot was a bit soft.  I don’t know much about photography, but I love taking pics of flowers, family, pets, and travel.  I realized that my x-t30 refused to take macros, so I got the mcex-16 to aid in that.  I tried auto, manual, everything under the sun (I think), to try and take pics of my new African violet blooms.  But my camera simply won’t budge when I press down on the shutter button.  What am I doing wrong?  Or is the Mcex-16 broken (it did come in a banged up box)?  Also, I’m pairing it with a 18-55mm Fujinon lens, which several people were doing in the reviews for the extension.
    • By yukosteel
      Initial lens review of Viltrox 85mm F1.8 lens on Fujifilm X-T30 camera.
      Hello guest! Please register or sign in to view the hidden content.
