You can post now and register later.
If you have an account, sign in now to post with your account.
Hi,
I just had the same message on my X-T3 and it would not go away with removing the battery.
It finally went away when I pushed the 'disp back' button. Very strange.
André
Is it always slow? Is it only slow in Auto mode? Are there specific situations when it is slow?
What do you mean by "camera is terribly slow"? DO you mean when writing to the card? Does the light flash when it is slow?
What card do you have?
Surely there isn't any point, as when you put a half pressure on the shutter release the lens stops down to is working aperture and so you get the same function.
Solution is to set Clarity off to "0", but that only works in Manual mode. What abaout AUTO? Clarity is blocked, it can't be change and the camera is terribly slow.
