Is this common? "Card Error" (recommended SD card in use).
bem
Hi all,
I have noticed as soon as I take any of my SD cards out (for file transfer to my laptop in the laptop SD card slot) and then later insert the SD card in the X-T4 SD card slot it is almost always this message in X-T4 when I turn it on: CARD ERROR
I take the SD card out of the slot in my X-T4 and insert it again and the error is gone next time I turn the camera on.
Little annoying, not a big problem since I know the workaround now.
Just curious, any others out there that has same problem?
The SD cards I use is on the Fujifilm recommended list of SD cards.
No other problems with my three SD cards I have. It is Sony Tough SF-G64T and SF-G128T (both V90) that I use.
/Bo
Edited by bem
This is unfortunately a recurring issue with multiple Fuji camera's. I've had an X-T2 suffering from this issue occasionally. My first X-H1 was almost useless because of this and the constant write errors. My second X-H1 rarely has it (knock on wood). My X-Pro1 and 2s never had an issue like this, but when I borrowed an X-T4 for a trial run, it also showed these issues. That's one of the (multiple) reasons I didn't upgrade.
When you use Fuji recommended cards, it also makes sense to use identical cards in both slots (I noticed you have 64 and 128Gb cards), to insert them gently and reformat in camera after securing the images. For the X-H1 Fuji launched a firmware update to solve this issue. Let's hope they do that for the X-T4 as well.
Is your laptop by chance a macbook? Mine is and apparently they contribute to the issue.
PS. I must say that the A7R4 nor the SL2 I'm currently using ever showed problems like these.
I had a single Sony Tough SF-G64T SD card initially alone in slot 1 and formatted it in camera in slot 1.
Later I bought two Sony SF-G128T that I had in backup so one was in slot 1 and one in slot 2. Both cards was formatted in the camera.
It seems not to matter if I use one or two cards in the slots.
It is not a big problem but it should not be like this with high quality SD card like the Sony Tough cards.
Once the card is recogniced, always on second insert of the SD card in a X-T4 slot, it works then perfectly.
I think I can live with it.
The cards has not been used that much, I have filled up the 64 GB card but the 128GB cards has still pleny of free space left.
I have a HP Zbook laptop with Win 10 so no MacBook in use here.
I have the latest firmware for both X-T4 camera (ver. 1.03) and lens XF16-80mm F4 R OIS WR (ver. 1.05).
Thanks for the answer, Herco.
Edited by bem
Something else to consider—Sony did have some bad batches of the Tough line of SD cards. I think they have a replacement program, the updated version has a very small asterisk on the back of the card before the letters and numbers at the bottom.
https://www.sony.com/electronics/support/memory-cards-sd-cards/sf-g128t/articles/00246463
Damn, I have two Sony Tough SF-G64T and two SF-G128T cards that all start with TV... on last row and no * sign either on the cards. I will have to contact Sony. I do not like really to send these tiny cards via mail, the cards are so damn expensive, and if they are lost in shipment it will not be cheap for me.
/Bo
  • 2 years later...
Just to add to the conversation, in case it helps anyone, I also just got this same error (or very similar) on my GFX50S II after 24 hours of owning it... I've had to send it back to the shop for them to send to Fuji (the shop's Aftersales Department said they've never heard of such a problem).
I'm using Sandisk Extreme Pro cards. They all work perfectly in Slot 1, but as soon as I insert any of them in Slot 2, I get the dreaded "Card Error"!
    • Looking for input; there are some decent deals and might want to take advantage to expand my lenses for my 100s already own: 110/2 32-64 35-70 100-200 + TC   Shooting mostly family shots, bringing my kit to capture family outings indoors and out. Tracking the 63/43 effective FLs on the two, but has anybody used both? Would the 55 (covered by two zooms right now) be redundant? Would the 80 be too similar in character to my 110 for portraiture?
    • See what I mean? Two instantaneous ads. Worthless.
