Xt2 flash problem
MacOne
Hi, I am wondering if anyone has had this problem. I can’t get My xt2 to recognise any flash or trigger. It is always in sync terminal mode. I have reset the camera numerous times and tried different flashes and triggers to no avail. It will fire in manual but get banding after 200/1ss due to no hss but still says sync terminal. Any help would be greatly appreciated.
 Thanks
Hi Olaf W,  thank you for your reply. It’s on mechanical only. It sounds like a pin problem not picking up anything on camera ? But yet it does fire the flash manual only but only up to 200/1 at shutter sync x 250/1 I get black band .
 Thanks
  • 10 months later...
Hi Sean, I had the same problem and I've cleaned pins from the flash and plates on camera with alcohol wipe and it worked. Probably it was just grease/dirt residue on it. I hope that will help you.
Edited by Patryksid
spelling mistake
Hi,
I just bought a Godox Xpro Transmitter and a Godox 685F in order to use with my X-T2.
When I mount my Godox 685F to my Fuji XT2's shoe, it works perfectly and appears in the flash menu, but when I replace it with the Godox Xpro transmitter the Xpro seems to be invisible in the camera, I guess that my camera should recognize the transmitter in the flash menu [SHOE mount FLASH] is it correct ]? Though it is not the case.
MENU>Synchronization terminal I have "M" or "OFF" as if nothing was connected.
I have set DIST triggering on 0-30 m triggering.
Firmware is up to date, battery is ok. So I don't know what is the issue, maybe a configuration error or a faillure.   Could it be something about the code switch ?
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
