Sign in to follow this
Zababo
X-H1 And Flash Nikon SB800 ?
Has anyone tried to connect an X-H1 with a Nikon flash SB800? Is that electronically compatible?
Shure TTL is probably not ok but in Manuel mode, is it useful?
Share this post
It should work without problems via the sync terminal. Only in manual, though. Just check the voltage on the hot shoe
Share this post
Hi Ileo
My problem is the voltage, the impedance and things like that, that could damage my camera ...
Share this post
You'll get manual and auto flash with the SB-800 but not TTL or CLS.
The electronics are low-voltage, so it's safe to use.
The SB-800 was the last of the great Nikon 'use on everything' flashes.
Share this post
Did not work for me.  However, I was able to use my SB700's and 800's on my XE1.  No go on the XT series, or the XH1.  I just gave up and went to Good flash and triggers.
Share this post
Loading...
