Anton
Hi all. Your assistance / advice will be greatly appreciated.
I use an XT3, and acquired the Godox 350 and Godox X1T remote trigger. For some reason, the remote trigger will not fire the flash off-camera. The following may be relevant:
  • When I have both the remote trigger and the flash off the camera, the test button on the remote trigger does fire the flash.
  • When the flash is on the camera, I works perfectly in all modes.
  • When the remote trigger is on the camera, it fires the flash when I press the test button on the remote trigger
  • When I press the shutter it does NOT fire the flash.
  • When the remote trigger is on the camera, the only flash setting available are Off and Manual.
From the above, it would seem to me tat both the flash and the remote trigger in fact work, but that either:
  • The remote trigger is not compatible with the XT3; OR
  • There is some setting on the XT3 that I need to adjust.
Any thoughts or experience with this equipment?
Regards and take care.
  • 5 months later...
Hi there
Does the X Pro F or the X1 f work with Fuji xt4 as when I have looked it has only mentioned the x-h1 xt3 and some older cameras.
I am looking to purchase the Godox 400ii and want to ensure all channels of communication are compatible.
can anyone assist
cheers
xennii
