XT-4 video lenses
Kasumi3344
What are the best zoom lenses and prime lenses for 4K 24 FPS video on the XT-4?  I'm looking to duplicate the film days as closely as I can.  The greatest like Steven Spielberg (Schindler's List, E.T. The Extraterrestrial, Duel), John Carpenter (Escape from New York/L.A., Big Trouble in Little China).
I plan to do Black and White, and color.
Thanks.
Edited by Kasumi3344
I picked up the XT4 three weeks ago and been testing the Mitakon Speedmaster 35mm F0.95.    Absolutely amazing.   VERY thin depth of field obviously but gives so much character.   Truly special.   I forgot to mention I’m a videographer.    So if your subject is relatively still and you’re decent at manual focusing you MUST try this lens.
    • HI Rufo, I have changed procedures.  I now use the colors space transform (CST) as my first node.  The CST is set up as follows: - Apply the CST effect to the first node. - Color Space is Rec 2020 - Input gamma is FLog - Output color space is Rec 709 - Output gamma is Gamma 2.4 All other nodes to grade the clip proceed the node that contains the color space transform. Hope this helps. Don
      Ohio River, Kentucky - Indiana, USA Ohio River, indiana - Kentucky, USA
    • Interesting, and a bit subtle. I also think it'd be better to activate on a half press. But there seems to be good reasoning behind a number of other choices, so I wonder if there's a good reason behind this one and we're just not seeing it. To some degree IS goes on and off like AF does, but this is an exception, isn't it?
    • I couldn't find my manual so downloaded a PDF copy and did some searching.  From p146 of the manual, regarding Shooting Only stabilisation: "Image stabilization enabled only when the shutter button is pressed halfway (focus mode C) or the shutter is released." So it appears that the camera is 'working as intended' and that in AF-S the stabilisation mechanism kicks in only as you release the shutter. I think I would prefer it to activate on a half press, like it does in AF-C.
    • Sometime a short break can help to phrase things so that they do not sound annoying, Well that is the hope anyway, so here goes. Having that meter would be nice as well as having the histogram. But having them or not is a minor consideration in terms of what you are wanting to do because the app does not work with intervalometers. The only way you can get a time lapse sequence using the app is to manually click the shutter button, wait then click it again and so on. Even if the meter were there, you would need extremely fast reflexes to see and react to a lighting change by changing the settings and then going back to clicking the shutter button. Doing that for hours would be a feat indeed. The equipment you mention does this by analyzing several past images and predicting what settings to apply to the next incoming image. Right now the app has the live view which will tell you if an area is over or under exposed, but as far as what you are wanting to do without being able to connect the app to an intervalometer, well …
