Sign in to follow this
Jay Bird
Front dial Aperture control is not working.
Hello, I've got a new XE3 with XF18-55 F2.8-4 kit lens. On the first day, I was able to change aperture using the front dial and also using aperture ring on the lens. But, now, I'm unable to change aperture using the front dial. When I see Aperture Settings, it is grayed out and is not working in camera settings. I have tried putting camera on Aperture Priority, but still the front dial doesn't change the aperture. Is there any other way this front dial can be made to change aperture?
Share this post
Loading...
    • Do you have your camera in Auto mode ? Try to switch that off. On my X-T10 Auto does only jpegs. (I would prefer if the camera would do Raw or Raw+Jpeg in Auto because if you hand it to someone else to take a pic and you put it in Auto for that, you loose the possibility to correct the image in PP from Raw.)
    • Are you using electronic shutter ? Switch to mechanical.
    • @maplineThanks for the answer,  I think i'm gonna opt for a wifi card instead, as it suits more my needs, (reducing transfer times and  timelapse real-time rendering). The hdmi thing would be ok if i wanted to capture video material, but i mainly do long exp/timelapses   Cheers
    • 1000 is a curious number - if you are using F-Log the minimum ISO is 640 - but haven't heard of any setting that restricts to 1000
    • I recently purchased a used Fujifilm X70 and there is something going on that I don't understand. Some times when I take photos the image comes up heavily distorted. It only seems to happen when I take a photo of a moving object, even at 1/1000 shutter speed and I'm not moving. I can understand some blur if my shutter speed is not fast enough, but this distortion? It only happens with moving objects, using manual and auto focus. I attached some images. The images are taken at 1/1000  F8. What co
