winspeare
Transfer settings to another camera
Hello,
I am thinking of acquiring a Fuji x100v as a second body to my x-pro3. I have set up the x-pro3 to my taste, including the 7 custom film settings.
i can save them to my Mac through x-acquire but will I be able to transfer this file to the x100 to have the same settings?
Thanks,
Nicolas
Share this post
Loading...
    • Do you have your camera in Auto mode ? Try to switch that off. On my X-T10 Auto does only jpegs. (I would prefer if the camera would do Raw or Raw+Jpeg in Auto because if you hand it to someone else to take a pic and you put it in Auto for that, you loose the possibility to correct the image in PP from Raw.)
    • Are you using electronic shutter ? Switch to mechanical.
    • @maplineThanks for the answer,  I think i'm gonna opt for a wifi card instead, as it suits more my needs, (reducing transfer times and  timelapse real-time rendering). The hdmi thing would be ok if i wanted to capture video material, but i mainly do long exp/timelapses   Cheers
    • 1000 is a curious number - if you are using F-Log the minimum ISO is 640 - but haven't heard of any setting that restricts to 1000
    • I recently purchased a used Fujifilm X70 and there is something going on that I don't understand. Some times when I take photos the image comes up heavily distorted. It only seems to happen when I take a photo of a moving object, even at 1/1000 shutter speed and I'm not moving. I can understand some blur if my shutter speed is not fast enough, but this distortion? It only happens with moving objects, using manual and auto focus. I attached some images. The images are taken at 1/1000  F8. What co
