It seems the Lcd tint has not been rectified in different bodies.
i really thought that Fuji would have seen the amount of complaints and worked on a resolution.
Heres 2 X-T30’s I bought within a month of each other side by side.
Totally reset and setup and still an lcd yellow tint is present.
Warranty exchange needed - even after adjusting lcd color and brightness etc. The EVF and LCD are showing same issue.
Ridiculous and a complete pain in the ass.
Brought back the X-T30 today and tried 3 in store - all exhibited same issue in varying degrees of yellow tint.
I was offered a refund but opted to try more as I shop regularly at the store. They have contacted Fujifilm to order others from possibly another batch to test.
Absolute joke in my opinion.
My X-E2s, X-T1 and evening X-M1 do t exhibit this problem.
I did order a 2nd X-E2s when B&H had a sale and it had the issue and had to be sent back also a few years back.
I’ll keep you posted.
  • 10 months later...
Loading...
    • Welcome to our forum!
    • Hi Chris, I've had the same experience with my 15mm 4.5f Voigtlander. VERY soft images outside the center, moved on to the Fujinon 18mm 2f and perfectly happy. Cheers,
    • mornin' every one,  New to the forum and the X system. Camera collector since the '90s. I've been swapping old "analogic" stuff for "old" digital stuff. So I ended up with a X-T1 and a X-Pro1, with 27mm and 18mm (small ) and a few adapters to play with the Legacy lenses. Still adapting to the mirrorless ecosystem 😞 Meh...!
    • I am thinking of adapting my sigma 17-50 f2.8 canon ef-s lens on Fuji xt3 via a viltrox speed booster. My biggest confusion is that will this effect focal length and light gathering of my lens?  An speed booster does so when adapting full frame lens on APS-C bodies. But what if I want to adapt an APS-C Lens on another APS-C body via an speed booster?
    • Hi Jozzef, same with my one. The pictures at 16mm are not as sharp, as they should be. I given the lens back. Others say it is a good universal lens. Maybe some has problems from production side?
