carrot
IBIS vs Lens OIS
The manual says if the lens OIS is switched on it overrides the camera IBIS, so I tried comparing the two systems hand-held with the 50-140 and 18-55 lenses.  In both cases, the lens OIS switched on was significantly better better than with the lens OIS switched off , i.e. than the IBIS.  Then tried the IBIS with the 16-55 lens which has no OIS, and the image was rock steady.  I'd be interested to hear what others have found doing this simple test.
Share this post
I also have the 18-55mm and I'm seeing the same results. It seems like the OIS switch on the lens turns off all stabilization. I'm working in the Video mode, so I don't know if there is any difference in the Photo mode.
Share this post
I've had a reply from Fujifilm UK on this now, and it confirms the last post.
They state "The OIS switch on any lens 'overrides' the IBIS setting in the camera.  If the camera is set to continuous and then the OIS switch on the lens is set to 'off', the IBIS switches off as well."
So if you have a lens with OIS it means the brand new IBIS is completely irrelevant, it may as well not be there.  IBIS is simply there for lenses that lack OIS.  I wonder if this means all new Fuji lenses will now come without OIS??
Share this post
That explains why I don't see the option to turn IBIS off in the menu with the 18-55mm, but do see it when using a Rokinon 12mm.
Share this post
I don't understand your argument.
Surely all this says is that you cannot have IBIS only if you have a OIS lens. It doesn't say that IBIS has no effect with an OIS lens and OIS turned on.
Share this post
Like on many other cameras, IBIS and OIS seem to be coupled: they are either both on or off.
For 18-55, Fuji lists 4 stops of stabilization on cameras without IBIS and 6.5 stops when using it on X-T4.
Share this post
I'm lost here
The OIS works  only on two axis: Vertical and Horixontal. The IBIS works on 5 axis, Vertical and Horizontal, as the OIS, adn adding 4 more: Yaw, Pitch and Roll. So od the OIS is ON its overriding the IBIS then I'm loosing the the other 3 axis (Pitch, Yaw and Rolls)?
Share this post
If You have a lens with OIS that has not on/off switch on the lens - what then? Like the lens XF 16-80mm F4 R OIS WR (that I have), it has no OIS on/off switch on the side, it is set in the camera Settings menu only to turn OIS on/off for video mode, Movie Setting:, IS Mode:
IBIS/OIS (I have that selected)
or
IBIS/OIS +DIS
or
Off
There is also IS Mode Boost that can be set to On (or Off)  (I have it set to Boost.)
For Still (photo) mode it is in camera menu Shooting Setting, IS Mode:
Continous (I have that selected)
Shooting only
Off
So for Video it seems it is is both IBIS and OIS  in ise but for Still (photo) it is IS Mode Continous I use - is it both IBIS and OIS then?
Thanks for clarification.
Bo
Share this post
Loading...
    • Does the focus bounce around when you are looking through the viewfinder? If so, it probably means that the menu setting for touchscreen focusing is turned on. Turn it to off in the menu settings and the focus point should only move when you use the joystick to move it around. Turn that setting to on when you want to use the back lcd screen as the “viewfinder” and then touch the spot you want to use as focus point. This is the cellphone method for focusing.
    • Which Canon DSLR are you referring to if I may ask?
    • Welcome here, Doug !
    • Hi mate,. I have the camera now and using the fringer pro and finding the focusing jumps all over the place. It doesn't 'lock' on to anything.  When it's sharp it's great but it sounds some time trying to work it out.   I'm using the canon 16-35mm f2.8 and the 70-200mm with similar results. The 300mm lens test was a bust but that was my fault as I was still in single focus mode and not continuous focus mode.  I won't make that mistake again.   What setting should I
    • Yes. I exchanged a couple and all their LCD panels creak and squeak like a cheap kid's toy. The XT3 I have has a much more solid screen casing. It also sounds hollow and as chap as on the X200. The rubber doors for the ports are also a downgrade. How is one to fix these when the rubber hinges eventually degrade and fall off- it doesn't seem to have a fix from the outside of the body. The video and photo quality is great but for a flagship it should feel like a precision instrument and it doesn't
