Fuji X-T4 with DJI Ronin SC
Have the same issue, but haven't test my SC with XT3 as I don't have one.
Trying to connect XT4 to Ronin via focus motor cable set with no result. Have ordered a USB-C to USB-C multi cable from DJI to connect XT4 directly to a Ronin. But it seems to me result will be the same till some upgrade from DJI and Fuji
I also have the same problem.  I have my Fujifilm X T4 connected via the USB C cable that comes with the kit from Ronin SC Pro combo and I can't control the focus and also the record button.  It is so frustrating.😭
Hi guys. After the firmware update on the Ronin SC the green charging light keeps turning on and off intermittenly (most of the time it stays off). Also the wall plug icon on the lcd screen does the same thing. I'm not sure if this is a faulty cable issue or a firmware bug because the start/stop recording still does not work for me.
Edited by lcaber
Hi, just got my Ronin SC and X-T4 yesterday. I updated the firmware on both, but am still unable to get the two to function properly together. I've set the connection mode on the X-T4 to "USB Tethering - Auto" but when the cable is connected between the two, it seems to only get power from the SC. Can anybody provide any insight?
Hey guys,
I'm just wondering how to combine the X-T4 with the Ronin-SC and headphones to monitor sound.
As you have to connect X-T4 and the gimbal via the USB-C port there's no option to connect the headphones anymore.
I'd like to use my X-T4 with the Ronin SC together with the focus wheel while maintaining audio monitoring with headphones.
Is there a working splitter for audio (3,5mm) and USB-C (Data-Connection) for the gimbal?
Kind regards
Hardy
Thanks for your suggestions. An external monitor should work, but that's quite an invest just for getting audio and gimbal functionality. Any suggestions for a working USB-C splitter?
The ESR 2-in-1 USB-C PD Headphone Jack Adapter has a note in its description: "Does NOT support data transfer".
Wonder if data transfer is needed for the gimbal.
ESR 2-in-1 USB-C PD Headphone Jack Adapter (Amazon)
You definitely need data transfer. Also given that the Ronin cable is only really USB-C at the straight end, the hub needs to be plugged in there.
  • 5 months later...
I just spoke with Fujifilm Professional Services via phone and they said that if enough people contact Fujifilm Tokyo headquarters making a request for gimbal support in the X-S10, then eventually they may add it in.
Here are the steps:
  1. Go to the Tokyo Headquarters Contact page: https://contact.fujifilm.com/cgi-bin/mail/form.cgi/contact_tokyo_headquarters
  2. Choose topic, "Digital Cameras". In Comments/Questions page say (feel free to slightly re-phrase so it seems more original :-): "I would like gimbal support in the X-S10 to shoot smooth video. For external gimbals like the DJI RSC 2 or the Zhiyun WEEBILL-S to work, we need USB MOVIE SHOOTING AUTO to be added as an option under Connection Mode. Can Fujifilm please prioritize this in a future firmware update?"
Loading...
    • Hi, I'm So Frutrated by this no tethering mode avalable on X-S10.   PLEASE Fuji: make an update for this.
    • Hi,i am looking for some useful video editing software, i hear about the TunesKit Acemovi and Adobe Premier is good,but i am not sure which one is suitable for me,i just need to do something simple like crop,trim,add text,audio,transition,animation.Can you give me some adivice? Here is a vision of a large selection of video editing softwares https://www.xp-pen.com/forum-1595.html Don’t forget that most of the time you can try them free for a while
    • Fan of X-Trans since P&S days Is RGB or RGGB better mosaics than Fujifilm's GBGGRGRB? How many bits of dynamic range and how few fractions of arc-seconds of resolution are needed for the more common pixel mosaics versus the more complicated X-Trans? Moire decreases with pixel size but photopic luminance for color channels and spacial frequency still matters. Debate, now, for your favorite mosaic!
    • Did you say iPhone? Their external mics usually have 4-conductor cables, which aren't directly compatible with anything else. Try an adapter with 3 conductors.
    • Welcome to  our forum! But I don't see an attached photo.
