orbeboy
ANY tips on how to shoot underexposed photos like this?
I believe the easiest way would be to switch to manual mode and just slightly underexpose the shot. Also, in an auto mode, you can use the exposure compensation dial to underexpose. Exposure for this image looks to be for light falling on the subject from the window. She just happens to be leaning in and has moved her face out of that exposure range (her shoulder looks properly exposed). If she sat upright, the let side of her face would be properly exposed. The kitchen would remain darker as the window light is "falling off."
Share this post
Posted (edited)
Yes, manual exposure or automatic and the exposure compensation dial, also using spot metering on her face as it is lighter than the background
Edited by Ish
correction
Share this post
On 7/20/2020 at 12:53 PM, Ish said:
Yes, manual exposure and the exposure compensation dial, also using spot metering on her face as it is lighter than the background
The exposure compansation dail don't work in manual mode, only in automatic mode.
Share this post
Posted (edited)
You have to setting at least your Iso in auto
Edited by LoloXpro1
Share this post
I guess your goal is to have the face stand out and the background 'disappear' in the shadows. Spot metering can be tricky since it very much depends on where you aim. There are great differences in luminosity in the face. If you need perfect exposure there are two options:  (1) meter on a grey card near the face and fix that reading in manual mode or (2) use a separate light meter for ambient light reading near the face. Both options are a bit cumbersome though. The multi-metering mode of Fuji is quite good and will take the focus point into account. So when you focus on the face and expose, it will know that is the main subject. However, to get the darker shadows, you may want to correct 2/3rds or 1 stop with the exposure compensation. In general make sure you don't overexpose on the left side of the face or on the shoulder, since in post processing it's easier to correct a slightly darker image than an overexposed one.
Share this post
Loading...
    • First of all the upgrades are for the positive most times.  It's a Fuji thing.  Compared to other camera companies they are always updating and making their cameras better. Not sure about the XT4 freezing issues but I'm sure they've been addressed in firmware.  However I use the XT1, XT2, XH1, and the GFX system and I've NEVER had an issue.
    • jerryy, Thanks for the advices. I really appreciate it. I have figured out as You have given hints about that I need to use more and more manual settings. Just I do not know enough so far what to change and to what value (or range). But I will start with what You suggested. I suppose as times goes and I learn more bit by bit and with trail and errors it will be easier. I used shutter speed Auto before but then I saw an "expert" saying 1/200 or 1/250 would be better so I tried that (just cha
    • HI there, i am a bit confused and hesitant. I am considering buying an X-T4 but seeing lots of people writing about them freezing amongst other issues. Also, having to continually update firmware seems like a pain especially given you need readers etc... What if you don't update ? Are all mirrorless like this ? No such hassles with DSLR's.  Can someone explain all this for me. Cheers.
    • yeah in the end i did. When i got it i immediately updated the firmware to the latest one. But i think i'm in love. this camera is great
    • That’s just the way it is
