Have you tried pulling out the main battery and leaving it sit on a shelf for several days to let the settings backup battery / capacitor completely discharge? This should cause the settings memory chip to lose all of its current settings and go back to the factory defaults — as of the last update.
Hi lolo, have to say I can't believe that this has not had more attention as you have done an absolutely incredible job here! I was in the exact same situation of moving from LR to C1 and really loving it except for missing my film styles pack and finding the native options available for C1 not quite there in terms of accuracy and quality. I looked all over the place before finding this post and links. What a relief! Many thanks for your efforts here mate, very much appreciated! cheers, LB
By Spider1000 · Posted
Hi there. I've just bought a second-hand X70 and I can’t seem to reset it to factory settings. When I choose reset in the menu I can't toggle to the required options, they're in red, all the commands I put in only toggles between 'ok' and 'cancel', the manual doesn't offer any help either. I would be very grateful for some help! Many thanks in advance. -
By bce.gatien · Posted
Dimsol, I will mention something that may be very obvious to some but this happen to me. The shutter speed was set on "A" while I was testing my X-T4 in dimm light. I was under the impression that my X-T4 was taking 2 picture, but is was just the shutter opening and closing at 1/4 sec timing. Is this the case or do you actually have 2 pictures saved on memory card per press ?
