Auto focus tracking - how do I turn it off?
By BokehBurger · Posted
I purchased a gently used XF 80mm f/2.8 aspherical macro for my X-T5. Not being familiar with this lens but having had experience with the Leica T mount 60mm macro and Canon and Zeiss macros, I was surprised that I felt what might be best described as a loose lens element that shifted when I tilted the lens, even before being mounted to the camera. In manual focus mode, the lens is fine, but there is a distinct “wobble” when the lens is in autofocus mode. I reported this to the company (I bought it from KEH), and they agreed this was odd and accepted it back for a full refund. I just got a replacement lens and the same thing is happening. I’ve never had an experience in which I feel a lens element loose inside the housing. Is this normal? Should I return it (again)? -
Old post but hope this can help. You have to make sure that exp. comp. is set to zero in P, S or A mode before you go in to manual mode. If the comp is set to, let say +5, and this is of the range for the settings in manual mode, twisting the comp dial (left dial) want do any changes.
