FX Admin
Capture One Fujifilm 20 – Save 25% with Code SPRING25
Buy Capture One Fujifilm 20 now and save with the voucher code SPRING25!
Until March 31, Phase One is offering a voucher code SPRING25 on the Fujifilm version of the Capture One 20 RAW converter, valid for perpetual licenses as well as for the subscriptions.
By the way: the newly released version 20.0.3 also supports Fujifilm X-T4 and Fujifilm X100V!
» Capture One Fujifilm 20 (save 25% with code SPRING25)
Share this post
Loading...
    • X-T2, 90mm (taken through a double-glazed window)   Hello guest! Please register or sign in to view the hidden content.
    • X100f stuck in A and P mode!  I just got my x100f back from servicing and even when I move the aperture ring and shutter dial away from A - it is still in A mode- if I move the aperture ring and shutter dial to A- I am in P mode.   I want M mode- I am pulling my hair out. Am I missing some step in settings or is my camera damaged from servicing?
    • By chance do you have the settings for touch screen focus turned on? If so, then every time you look through the view finder, the focus point will bounce around like you are describing. Make certain it is turned off in the menus. That setting is more intended to be used with the big lcd screen.
    • I have an XT2 and have no issues transferring images from that camera. With the X100V, I'm getting really, REALLY frustrated and tired of not being able to use the app to transfer images.  - I had no problem pairing the devices. - I have opened the Fuji Remote app and have Fujifilm-x100V-18B8 visible with a flashing bluetooth icon and a solid wifi icon. - The camera says: iPhone-7459. Start Up Fujifilm app for digital camera and select the function Fujifilm-x100v-18B8.  - When I selec
    • I acquired an X100V this week and have the same issue as that described by Joe Zhou. Compared to my XT3, its extremely loud. Compared to the Canons I have used it is very noticesble and a bit off-putting. Are such noises the norm with this camera?
