How many of you (users) have / ever used 2.5mm remote
radul
I wander about those 2 things
hoe maya people use 2.5 remote ? - i have only just found the slot on x-t3
and second question how many even have something like that?
maybe it is something to make an fujirumors questionnaire about...
is the remote jack slot really needed on x-t3/ x-t4 cameras? or the next one?
Edited by radul
I use it heavily for macro shots and remote triggering.  I also used it this weekend to control a time lapse since for some reasonm if I want to use the built in intervalometer, any interval that is longer than ~15 seconds causes the camera to just stop at about an hour or so in.
