Danny Bates
Godox Flashes Not Firing at Slow Shutter Speeds (below 500)
Is anyone else having this problem?
My XT2 works beautifully with my Godox flashes (two AD200s and one AD600) when my shutter speed is 500 or higher. But if I drop the shutter speed below 500, the flashes stop firing.
I'm using the Godox XPro-F transmitter.
So what I'm really wanting is "Low Speed Sync" so I can use my Godox flashes at speeds like 1/60, 1/125, 1/250, etc.
Why I do not suspect the transmitter or flashes
  • I can press the test button on the transmitter and the flashes fire
  • I can put the same transmitter on my X100s and shoot at any shutter speed and the flashes fire successfully
This makes the XT2 my prime suspect.
Under the flash function setting menu, I do have Sync Mode set to AUTO FP(HSS) but I've tried the other settings with no success either (and didn't expect those to help anyway).
I am in single shot mode and not using bracketing or multi-exposure features.
And it doesn't matter if I manually turn off HSS via the menus on the flash units.
Do you have any suggestions I can try next?
Can you see if you are able to shoot and sync at 1/60 using your XT2 and Godox transmitter and flashes?
Any help or suggestions will be thoroughly appreciated!
Share this post
Is the camera in manual mode?
Is HSS turned off on both the camera menu and the flash menu?
Is the firmare up to date? I recall one of the X-T2 updates improved radio flash control.
Is the flash trigger firmware up to date?
It occurs to me that when the flash is in HSS, it is expecting to flash at lower power multiple times....I don't know why this would affect only one camera, but I'm still thinking...........
Edited by itchy shutter finger
Share this post
I called Fujifilm XT2 support and they answered within 2 rings and were most incredibly helpful!
After about 30 minutes of troubleshooting, we discovered my mechanical shutter was going bad - specifically the second curtain. While I'm not glad there's a problem, I'm glad to know what it is. I'll be sending the body to them for repair, which should take about 2.5 weeks. I'm very happy with that.
Share this post
On 1/29/2020 at 9:28 PM, Danny Bates said:
1/500th of a second, shutter speed
so below 1/500th is 1/1000th?
or if you understand what I understand: 1/250th is slower. But at 1/250th or 1/125 shutter speed, you will not need high speed sync? And please let me tell you that from the flah point of view, HSS operation is pure stress. It has to swich on / off / on / off at a very high frequency for at least 1/125th of a second; exactly: all the time the open curtain slot needs to travel across the sensor. If you use - say 1/30 - shutter speed, it's about 4 times longer! That's not easy to implement because of energy issues - you need a bigger capacitor, you must figure out how to get the energy from a huge capacitor to the flash bulb, and you must dissipate a lot of energy in your cooling system!
Share this post
22 hours ago, Vinícius Cruz said:
Friend I have the same problem as you managed to solve?
I can't say I solved it. I can only say I trust what the Fuji technician told me. It makes sense to me that the mechanical shutter was the cause. I just now packaged the camera body to be returned. So it will probably be 3 or 4 weeks before I can confirm that the mechanical shutter was the problem.
If you want to do the same test he had me do:
  • set your ISO to 6400
  • set your shutter speed to 1/8000
  • set your aperture to f/2.8
  • set your shutter type to mechanical
  • take a photo of a low contrast subject, such as a gray wall with something off to the right or left of the frame
  • now set your shutter type to electronic
  • take another photo of that same subject, using the same composition
If the photo taken with the mechanical shutter was a lot lighter than the other, this suggests your mechanical shutter is failing. Otherwise, the two photos would have the same exposure.
I've attached the results from my test.
Edited by Danny Bates
Share this post
Loading...
    • By Filand
      Hello,
      I have a quick question regarding the XT-2.  I jumped from a Canon 40D to the XT-2 some time ago.  I love the camera and the feel and output are fantastic for me.  With that said, I have noticed that I have a harder time (on the Fuji) transferring what I see in my viewfinder to my computer screen.  In other words there seems to be a disconnect between what I see in the computer and what I remember being in the viewfinder.  I don't think it is a color or exposure issue, maybe a framing?  Not quite sure.  Do I simply need more experience with the camera?  I'm using a 18-55 for both cameras.  Thank you.
    • By Thubten
      I have used cameras for a long time, none of them weather sealed, without any damage from water or dust.In fact I don't recall it even being an issue.But now I am deciding between an xt2 and xt20 ,mainly on this basis and the $700 price difference.I will never be out in the rain with this gear, but it will be exposed to ordinary dust, and perhaps high tropical humidity.I am leaning towards the xt20.This has perhaps been covered before, but I can't find a search function.
    • By AKXt2
      Hello Everyone,
      I just picked up an XT2 and this is my first Fuji camera, really excited about using it. I've been watching a lot of youtube videos and reading forum post to familiarize myself with the camera and its settings. I am very impressed by the film simulations but really confused on how to use them in conjunction with RAW files. I was under the impression that if I shoot RAW+JPEG(Fine/Norma) with a film simulation selected (e.g. Chrome). Simulation is applied to JPEG only and RAW file is pure raw without any processing that I can edit however I want in post processing. But I took the camera out for the first time and realized the film simulation is applied to both JPEG and RAW. Is there a way to shoot with film simulation applied to JPEG but get unprocessed RAW files from XT2?
      Thanks for everyone's help in advance!
    • By Howling Basset
      Hello ... bought the Godex V1 and use it on an X-T3 ... seems nice enough BUT ... it just sometimes doesn't work or rather it makes my Fuji seemingly go to electronic shutter and results are very overexposed. Solution is to turn either camera off and on again or the flash off and on again. Trawled the net but can't see to see anything. Sent in a request to Godox but they're obviously never going to get back to me. Anybody had similar issues or am I missing something very obvious? Camera and Flash have latest firmware. Andy
    • By Giovanni1968
      Hello,
      I am seriously thinking it's about time to upgrade my X-Pro1 to an X-T2, I don't need latest gimmicks nor super high res or movie features, for extra MP I use a FF Nikon camera which has plenty of pixels, Fuji is for lighter shooting like hiking, travel etc and as such, given how many people upgrading to the X-T3 the T2 reached a price tag which fits my budget.
      I see many T2 on American photography boards for sale but I live in the EU and the only reliable source I know is an online store in the UK (dunno if allowed here to past a link or a name so I just won't this time), is anybody aware of other trusted sources within the EU borders for used gear?
      Grazie
      Giovanni
    • It all depends on what you want and need, a cheap option with TTL is the Nissin i-40 as mentioned above if you use manual flash (which I would recommend) Youngnuo is a very affordable option also offering remote triggers for off camera use.  I have the nissin i-40 whish is easy to use and offers TTL and a couple of Youngnuo Flashes with remote triggers.
    • Any street/public photos of Hong Kong (Open Thread)     Hello guest! Please register or sign in to view the hidden content.
    • I live in Yuen Long, Hong Kong.  Just bought X-E3, X-T30, 16mm 1.4/f, 18mm 2/f, and 35mm 1.4/f.  Here is the set of photos I used them to record Yuen Long, Hong Kong.  I only use the Film Simulation of Acros Red.  I will keep updating this album.  Cheers!
    • Hello guest! Please register or sign in to view the hidden content.
    • (From an older inquiry I responded to here) I bought the pair listed below. Both are made by Godox but are rebranded house brands from Adorama. B&H also has Godox rebranded house brands though I don’t know their name for it. The reason I went with Godox is they are inexpensive and rated very high on multiple websites.  I first bought the pair as Godox branded but the warranty was a joke. The flash and off camera support both had a card insert explainin
