New Fujifilm GFX Lens Roadmap Shows Serious FAST GLASS
By JovialLich · Posted
Hi everyone I find why it did that, it was because I shot with the flash at the second curtain.
Daffodils (Appalachian) Eastern Red Bud -
Does it use wi-fi when you are not specifically attempting to transfer files?
