arturk9
Fuji XT-2 very sensible turn on
It takes a very light pressure to turn the on/off switch on or off on my XT-2.  It is very sensitive.  I don't know if that is normal or not.  I would like to know what other XT-2 users think.
Share this post
My X-T2 doesn't 'work' that way. If the On/Off switch is turned on, that will illuminate the screens just fine, but then the initial touch of the button only triggers the camera to focus and set its' exposure. I have to push further to make the trigger go off. Quite controllable, to my mind.
I just tried this with my camera settings the same as yours (Single shot, Averaging metering), so I suspect there may be something in your various settings that may be triggering this (forgive the pun). Hope you're able to figure things out, or it may be time to send it to Fuji for a quick repair; I would suggest that you send that video you made to your local distributor and see how they respond. Best of luck!
Edited by CDBC
Diction
Share this post
Loading...
    • It all depends on what you want and need, a cheap option with TTL is the Nissin i-40 as mentioned above if you use manual flash (which I would recommend) Youngnuo is a very affordable option also offering remote triggers for off camera use.  I have the nissin i-40 whish is easy to use and offers TTL and a couple of Youngnuo Flashes with remote triggers.
    • Any street/public photos of Hong Kong (Open Thread)     Hello guest! Please register or sign in to view the hidden content.
    • I live in Yuen Long, Hong Kong.  Just bought X-E3, X-T30, 16mm 1.4/f, 18mm 2/f, and 35mm 1.4/f.  Here is the set of photos I used them to record Yuen Long, Hong Kong.  I only use the Film Simulation of Acros Red.  I will keep updating this album.  Cheers!
    • Hello guest! Please register or sign in to view the hidden content.
    • (From an older inquiry I responded to here) I bought the pair listed below. Both are made by Godox but are rebranded house brands from Adorama. B&H also has Godox rebranded house brands though I don’t know their name for it. The reason I went with Godox is they are inexpensive and rated very high on multiple websites.  I first bought the pair as Godox branded but the warranty was a joke. The flash and off camera support both had a card insert explainin
