rocky beach in b&w
roicead
thanks guys.  i've had a coworker tell me she couldn't print my photos without the big ugly watermark and there was no way she was hanging that on her walls at home.  funny thing is, if i knew she was interested before she said that i probably would have just given her the prints...
thank you lluisig, i do the conversion in lightroom.  i haven't had good luck by hitting the b&w button in lightroom, i just leave it in color.  i slide the saturation slider to -100 and adjust the tones and contrast to fit the image.
