Sign in to follow this
falevian
Astrophotography, Vía Lactea
This picture was created with 6 photos at 20s, ISO4000, F/2.0 with the Fuji x-pro1 and Samyang 12mm. I used Photoshop for align the 6 photos. The converted it to smart objet and use the stack option called "median".  By doing the mean or median, you are separating the signal to the noise. If the relation between boh is bigger enogh, you can see more details in the nebulae in the astrophoto.
Share this post
How do you compensate for the movement of the Earth? 6 photos at 20 seconds gives 2 minutes, that is a lot of time
I am interested because I'd like to do some astrophotography, but the first results aren't very exciting
Share this post
That's the "used Photoshop for align the 6 photos" part. In astrophotography image processing is at least half the work. You can't do wonders if the original images are bad, but even if they're as good there's still tons of processing to do before you end up with a great picture of the milky way or other astronomical objects.
I posted this list in an earlier topic, but I guess it might be useful here as well:
Despite the topic, this isn't really X-T1 specific thread. Might be useful to move this to more appropriate area. Although I'm not sure which one that would be.
There's really no magical way to get rid of the noise. Increasing the exposure time and stacking exposures will help in getting rid most of it. Noise reduction algorithms will always remove some of the dimmer stars, but usually isn't really a problem since those faint stars wouldn't be visible in the final image anyway.
I doubt anyone here can give you better advice than what can be found from a number of different online tutorials, such as (these are in some kind of order, just don't ask me what it is):
http://www.lonelyspeck.com/
http://www.astropix.com/index.html
http://theartofnight.com/2014/06/the-art-of-astrophotography-tutorial/
http://www.astro-imaging.com/Tutorial/PixInsight/M33/en.html (processing tutorial)
https://www.reddit.com/r/astrophotography/comments/2acnqb/the_great_list_of_astrophotography_software/ (software list)
http://www.deepskycolors.com/
http://www.skyandtelescope.com/astronomy-resources/astrophotography-tips/
http://www.astropix.com/HTML/I_ASTROP/toc_ap.html
https://photographylife.com/astrophotography-tutorial
Few other useful links:
http://app.photoephemeris.com/
http://www.lightpollutionmap.info/
http://www.blue-marble.de/nightlights/2012 (and the rest of the blue marble site)
Share this post
Loading...
    • By paulbroad
      British heavy bomber rear gunner. Museum display. XT-3 focus stacking feature.
    • By jsgphotofx
      I took a series of RAW night shots using X-T2, when doing the post processing using Star StaX the end result had an odd pattern.  I used Lightroom to do the initial process, saved as full-res jpegs, then ran them through the Star StaX app. The result looked great at first look then discovered this odd vortex looking pattern.  It seems to be in the same location in all of the star trail photos that I processed. I've done some research but don't seem to find much information.  The only thing that I have found was that it was caused by the lens correction done in Lightroom, however, in Lightroom with my X-T2 the lens correction says "built-in Lens profile applied" and there is no way to get rid of the lens profile.  Is this the cause?  Can anything be done to get around this problem?
      Hello guest! Please register or sign in to view the hidden content. Hello guest! Please register or sign in to view the hidden content.
    • By Plaatje
      Did post this in another Fuji forum, so why not here?
      and there are many more . . . .
      maybe you like it. (I did).
    • Follow these steps: - put an empty/formatted card in the camera - go into Set Up/Save Data Set-up/Frame No. : change to RENEW - take a single picture (this will be DSCF0001), turn off the camera and remove the card - copy your original picture (DSCF1478) onto the card (You could also change the name of the DSCF0001 file in your computer if you no longer have the original DSCF1478) - put this card in the camera and turn it on - before taking any pictures change RENEW
    • I have the 10. I don't think the 13 will fit. The 10 fits tightly into the bottom of the pack, which is good because it won't get shaken around.
    • Hello i just bought universal flash yongnuo yn560 III and trigger PT 04NE for my XA5 camera, but i cant use at all. I already searching on google the problem was i must change to mechanical shutter I was open fujifilm website , there is setting for shutter type in camera, but i cant found in my XA5 camera My question : 1. How to use Mechanical shutter in XA5 2. Why i cant use my universal flash   thanks in advanced
    • Can I update X-T2 firmware from ver 3.00 to ver 4.32 in one step?
    • im new to this forum but no stranger to fuji  @LEEP sorry to hear your having issues as well!  I’ve been shooting on an xt1 since the first release, I just upgraded to the xt4 last week.  As soon as I unpacked it, fiddled with it and connected it to my phone, it prompted for a firmware update and I figured why not.... bad move? Jury is still out.  since then, randomly, maybe every third time I go to use the camera it won’t turn on. I’ll have to completely remove the battery and put it b
