Fuji 18mm F2 thoughts?
abjurina
A lens lacking of dynamic range? I think that something is askew in the use of terminology here...  if you talk contrast ( and the picture above shows plenty of that and range to match) this could be but it doesn’t seem to be the case so it is either your lens, or, I suspect, the way you have set up the camera.
Maybe reading the manual, albeit once again or for the first time, in order to set the camera properly up, once and for all, would help.
Like many others, it's "love vs. hate" with this lens: love the size and FOV! Hate that this is the only lens out of all Fuji (primes) line up I have, that I need to watch out and correct in LR when developing files (aberrations, sharpness, etc...).
I wish Fuji will update this lens with same size, max. F-stop of 2.0 and improve obvious inferiority to the rest of the prime champions...
My 2/18 on the X-Pro1 is clearly better than the Canon 1.8/28 (same FOV on the 5D) that I had. Yes, the other Fuji primes that I have are optically better, and no, I'm not really bothered by that. In many cases, the action is not going on at the extreme edges of the image, and I like the images this lens produces.
...I'm not really bothered by that. In many cases, the action is not going on at the extreme edges of the image, and I like the images this lens produces.
Most of my work with Fuji X system get submitted to stock agency. Issue with 28/2 becomes at the point when I have to "pixel peep" every file for chromatic aberrations or (near center) lack of sharpness due to poor quality of image on 2.0-2.8 range (my usual working F-stop with this lens).
I would say 75% of images are great with this lens, but I need it to be far closer to 100% as other Fuji primes I have.
Again, this is totally nitpicking... Comparing to any other lens system I used i recent years on digital (except Leica, but being manual focus - not classified). My Fuji line up is so much better in performance than prime EOS kit I use to own or large FX kit from Nikon I use now on my D800/D810...
Being primarily "wide angle" shooter, my 14,18, 23 give far better performance than anything else. Even Leica M glass I owned (again being manual focus and only used  on range finder) did not give me such a high number of "keepers"...
FU2I9159
Many photos by Cartier-Bresson, Doisneau, Erwitt and others, whose abilities are beyond question, are blurred, grainy and slightly out of focus, but they are world-class photographs.
Many of mine are the same, but it didn't stop over one million people visiting my Milan exhibition in 2014 and 2015, and strangely enough, the imperfect photos were some of the most-loved by the visitors.
Perfection is a myth - it's boring.... and while most photographers are still messing around trying to get 100% perfection, the real photographers have already grabbed the most poignant moment and syndicated it worldwide.
Sometimes you can be lucky and get near perfection in the second it takes to grab a stunning photograph (posed or contrived photos are never stunning), but perfection is simply not important compared to capturing the decisive moment.
The 18mm lens has caught me some amazing photographs that have never been refused by any publication.  Post 16 of this thread is one such example.  The expressions of all the people looking at the old man far outweigh any softness that a pixel peeper might find in the corners.
I like the 18mm, a lot of the time, but not always. I've got no complaints about its quality or size and I think its a steal at the price (i bought mine used for about £170).
However I sometimes find it too wide and the 27mm not wide enough. Obviously my answer would be the 23mm, but apart from it being too expensive for my pocket, I also think it's bigger than what I wish to carry around.
Anyway below are some shots that I took with the 18mm that I feel demonstrate that it's no slouch.
18mm, f5.6, Barcelona
24114344291_7129453660_k.jpgBarcelona Streets by Magnesi Rich, on Flickr
I am curious why people are posting just photos here.
In the context of this thread, photos would be ok in support of text, but on their own I don't see them as valid input on a discussion thread.
The OP asked for thoughts on the 18mm lens, but it seems the thread is deteriorating into a gallery for people to simply show off their images.  There are many other threads where you can show off your photos, but it would be nice not to have to wade through meaningless images to find the real discussion in what are obviously discussion threads B)
I have been using my trusty 18-55mm Fuji kit as a reception lens, but lately it's been having a really tough time focusing in low-light scenarios. I know that I generally shoot most of the time at 18mm at 2.8. I am wondering if the 18 f2 would be a better low-light performer? The 16mm is also an option, but if I'd prefer to save the cash and weight if possible. Any thoughts or experience with any of these?
I use my 18/2 a lot, in my opinion it is a superb low light option. The difference between your 18-55 at 18mm and 2.8 and the 18/2 at f2 won't be huge and there is no anti-shake on the 18/2 but in my opinion, it will be slightly better and I would choose it over my 18-55.
Just one more thing to note with the humble 18mm, it's currently the only X system lens at gets to 1:1 with the macro tubes:
http://www.fujifilm.com/products/digital_cameras/accessories/pdf/mcex_01.pdf
I know some people think this is important. Pretty insane working distance but nevertheless...
Edit: just noticed the xc 16-50... Not that 2mm is useable.
  • 1 year later...
Stick with your 18-55 until the 18 mk2 comes out.
The 18mk1 is a very normal lens. Nothing to shout about. Soft corners and colors are a little dull.
Personally I would go for the 16mm. It's wider and two stops brighter then the 18-55. Since you're experiencing difficulty because of a lack of light I would play it save and go for the f1.4 option. F2 might not make enough of a difference to justify buying another lens.
Edited by Mervyn
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
