LONELINESS / SOLITUDE
Paul Crespel
Towns and cities are places where you can feel very lonely, even surrounded by so many people.  Sometimes you choose to be alone for a while, but not everybody is fortunate enough to have such a choice.
13355590755_304d8aaf7b_b.jpgBardolino sky by Paul Crespel, on Flickr
13355725593_c77f23e195_b.jpgDignity by Paul Crespel, on Flickr
13355555555_d5c68471d8_b.jpgMara's Bar Cembra by Paul Crespel, on Flickr
13355689893_6f27a5cf96_b.jpgOutlook by Paul Crespel, on Flickr
13355509805_802b63babf_b.jpgVerona Curiosity by Paul Crespel, on Flickr
13355890324_72c71d8f40_b.jpgHomeless in Verona by Paul Crespel, on Flickr
Very nice series Paul.
Do you have any tips for photographing homeless people ? Do you talk to them before or try to go unnoticed ?
I've often wanted to do it because they are so interesting people, but I got yelled at once by a tramp for taking pictures of him, which makes me reluctant now. I think vulnerability is really hard to work with, both with the subject and in the resulting picture. When it's well done though, it usually gives emotionally powerful images like yours.
Hi Guillaume :)
I'm not sure what to advise, but I will try.
You should follow your instincts.  It's something you either have or you don't have, and I don't think it's something that is easily learned from somebody else.... you have to use your own judgement.  You will know when you get it right.
I have the advantage of having spent over 20 years as a photoreporter, many years ago now, but I don't know how to explain or advise others, as every situation is different.
Some of the work I did caused me to have to live in less than ideal conditions for extended periods, so in a way I've been where they are now, and maybe that shows in my approach to them.... I don't really know.
The one very important thing you might want to keep in mind is that no matter how difficult a person's situation seems to be, you must always allow them dignity, and treat them as fellow human beings; treat everybody as you would treat your own parents or grandparents.
Lonely or homeless people are PEOPLE.  They aren't tramps, or vagabonds, or criminals... they are people who, for one reason or another, are facing difficulties.
Maybe another point to consider is WHY you want to photograph them.  Is it just to get a great photo?  Is it just a personal challenge?  Those aren't always the best reasons to document social issues.
Think long and hard about why you want to do it.  If you think you're up to making a statement on their behalf, and if you're sure that they would approve of the way you approach it, then go ahead.  But also consider that even with the best intentions in the world, you could end up humiliating them.
It's not the easiest subject, but a degree in psychology might help, as would a thorough examination of your motives for wanting to cover such issues.
Good luck :)
    • Some elements in (autofocus) lenses are „floating“, so I guess what you are experiencing is normal.
    • How do I turn off the electronic shutter in the menu - the option is grayed out and I cannot select the mechanical option
    • I'm having trouble finding a way to attach a right-angle viewfinder to the Fuji X-H1 camera. Does anyone have experience with how the angle viewfinder behaves in combination with the EVF? Is the Minolta frame diameter of the right angle viewfinder suitable for attaching to the Fuji XH1 (or XT1, 2, 3, 5)? Does anyone have knowledge about which eyepiece is compatible with the Fuji X system? Thank you in advance for any assistance and information you can provide.
    • I purchased a gently used XF 80mm f/2.8 aspherical macro for my X-T5. Not being familiar with this lens but having had experience with the Leica T mount 60mm macro and Canon and Zeiss macros, I was surprised that I felt what might be best described as a loose lens element that shifted when I tilted the lens, even before being mounted to the camera. In manual focus mode, the lens is fine, but there is a distinct “wobble” when the lens is in autofocus mode. I reported this to the company (I bought it from KEH), and they agreed this was odd and accepted it back for a full refund. I just got a replacement lens and the same thing is happening. I’ve never had an experience in which I feel a lens element loose inside the housing. Is this normal? Should I return it (again)?
    • Old post but hope this can help. You have to make sure that exp. comp. is set to zero in P, S or A mode before you go in to manual mode. If the comp is set to, let say +5, and this is of the range for the settings in manual mode, twisting the comp dial (left dial) want do any changes.
