Bokeh Club
eagle_friends
Guys, that's what I'm looking for as tips. Can someone instruct me on how to get these results?
There are at least three options to get a nice bokeh shot.
- use a long focal length, e.g. >50mm
- get close to the subject (you can also use macro rings/extension tubes or macro lenses to get even closer) and keep a decent distance to the background
- use big apertures, e.g. f/1.4
All these three can also be combined. Here you can see how it all works together: http://www.fuji-x-forum.com/topic/317-135mm-lens-comparison/
135mm, f/2.5, 3m subject distance, ~13m background distance
now with the capture
Liveimpression
https://500px.com/liveimpression
A couple with the X-T1 and XF 60mm Macro
Fuji X-T1, 56 1.2 APD. Love the bokeh from this hunk of glass...
I just took a couple of sample photos with the new 90mm F2 lens.  I am not a professional but this lens is a winner so far.
These are untouched jpegs right out of camera.  If I am in the wrong thread let me know.
