Clicky
Back Button
  • Please log in to reply
12 replies to this topic
#1 robk47
robk47
    Newbie
  • Members
  • Pip
  • 6 posts
  • Locationthird planet from the sun
Posted 05 July 2015 - 02:10 PM
Advertisement (Gone after free registration)
This is probably a question that has been asked and answered many times, but what are the menu settings to get back button focusing on the X-T1, please?
#2 Antony
Antony
    Advanced Member
  • Members
  • PipPipPip
  • 174 posts
  • LocationTamworth, NSW, Australia
Posted 05 July 2015 - 02:45 PM
Set the camera to manual focus, press back button.
Professional wedding and commercial photographer from Tamworth, NSW, Australia.
www.chasingsummerphoto.com
#3 aceflibble
aceflibble
    Advanced Member
  • Members
  • PipPipPip
  • 207 posts
Posted 05 July 2015 - 02:47 PM
There aren't any. With the camera set to manual focus, back-button focusing works. With single or continuous autofocus, the shutter release always initates focus, and the AF-L and AE-L buttons lock the focus and exposure. (Or you can make one of them lock both simultaneously.)
Yes, it's silly and not in any way ideal. No, I don't know why Fuji haven't put in a simple back button focus option yet. Since they've not done it yet I find it unlikely they'll ever do it.
#4 Dis
Dis
    Advanced Member
  • Members
  • PipPipPip
  • 226 posts
Posted 05 July 2015 - 08:18 PM
That's not fair. Some people didn't believe Fuji will implement EC in manual with auto ISO. Now we have it. Fuji listens and does.
#5 french02chris
french02chris
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 05 July 2015 - 08:40 PM
I am not sure that we are talking about the same thing here..BUT
I usually press the AF-L on my X-T1, it does focus..then I press the shutter to take the photo...
AND I am in autofocus mode...
In the menu : AF-L is on AF-L Lock Mode
and  AE/AF lock mode is on P ( for pressing)
#6 aceflibble
aceflibble
    Advanced Member
  • Members
  • PipPipPip
  • 207 posts
Posted 05 July 2015 - 10:24 PM
^^ That's almost right, but true back button focusing stops the camera from trying to focus when you press the shutter button. The AF-L does still cause (and locks) focus, but so does the shutter. Fuji does not offer the option to stop the shutter from activating autofocus, other than switching the camera to manual focus mode.
 There's a truckload of things people ask for that never happen. Proper back button focus has been one of them from the very start. It's also one of the most straight-forward fixes. They've changed functionality and function options of many buttons (most recently the macro button), so if they've not sorted proper back button focusing yet, it is very unlikely they ever will.
Note that, again, I use the word 'unlikely' and not 'impossible'.
#7 Antony
Antony
    Advanced Member
  • Members
  • PipPipPip
  • 174 posts
Posted 06 July 2015 - 03:57 AM
I don't see any reason for Fuji to fix something that's not broken. Rear button focus works perfectly, just set your camera to manual focus then press. Why would Fuji need to implement a change when this works fine? I don't see what functionality is missing that would be addressed by any change.
#8 aceflibble
aceflibble
    Advanced Member
  • Members
  • PipPipPip
  • 207 posts
Posted 06 July 2015 - 04:21 AM
The problem is that there's no way to only have back-button focusing. Either you have it so the shutter still activates the focus or you have it so moving the focus ring will shift focus, and the rings on the newer lenses are very sensitive. It's pretty much impossible to hold a Fuji camera without some part of one of your hands touching the focus ring in some way. If you're trying to get perfect focus with something like the 60mm lens up-close or the 56mm lens at f/1.2, that is a huge, huge problem.
By allowing proper back button focus to work in AF-S and AF-C modes—AF-L activating focus when pressed and disabling the shutter from initiating focus—you would no longer have the risk of accidentally shifting focus with the manual focus ring.
#9 Dis
Dis
    Advanced Member
  • Members
  • PipPipPip
  • 226 posts
Posted 06 July 2015 - 07:06 AM
Current back button focus works only like single point AF. You can't make it work in zone AF. It's also a long menu travel to switch from single AF to continuous. Proper back button focus should work in work in AF-C as continuous and in AF-S as single without menu fiddling and with ability to use zone and wide AF. Also half pressed shutter button locks the exposure.
#10 Antony
Antony
    Advanced Member
  • Members
  • PipPipPip
  • 174 posts
Posted 06 July 2015 - 09:11 AM
Thanks for the clarification, I can see these would be beneficial changes.
#11 zachtgray
zachtgray
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 16 January 2016 - 07:16 AM
I was hoping this would be something that was addressed in X-Pro2 but it doesn't seem to be. Sports shooters rely on true back-button AF and with the stated improvements in the AF abilities, now would be the perfect time for Fuji to give us back-button AF.
#12 yukosteel
yukosteel
    Advanced Member
  • Members
  • PipPipPip
  • 246 posts
  • LocationBellevue, WA
Posted 16 January 2016 - 09:24 AM
I shoot 100% using AF-L for autofocusing on X-T1, and never use half-shutter for focusing. It's a habit adopted from slower focusing X-E1.
I tried to use AE-L for back-button focusing for some time, but it's not so convenient.
Also I've recently noticed that autofocus works faster if AF-L is set to lock Focus Only. If it's set to Lock AF/AE then camera first locks Exposure, then proceed with autofocus - weird : \.
#13 JRphoto
JRphoto
    Advanced Member
  • Members
  • PipPipPip
  • 93 posts
  • LocationTerra
Posted 05 February 2018 - 06:39 PM
It is  interesting to notice that using lens with focus clutch mecanism (2,8/14, 1.4/16, 1.4/23), setting X-T1 to manual focus and leaving the clutch mecanism in AF, you can back button focus (BBF) with the AF-L button (you can change this to the AE-L button using the menu, if you want), the shutter will not refocus, and there is no risk to accidentally change the focus manually. So, with these lenses you can have the BBF experience with AF-S but not with AF-C (but the AF-C in the X-T1 is not great anyway). Edited: yes, you can have the BBF experience with AF-C also: you just need to go to Autofocus Setting --> Instant AF Setting and set this to AF-C.
Edited by JRphoto, 05 February 2018 - 07:01 PM.
X100S, X-T1 & X-T2
x
Registration is free
Not registered? Really?
Discover the full potential of the Fuji X Forum... register now!
Registration is free and done in a few minutes!
As registered member you can discuss, post your questions and present your images.
And get in contact with Fuji X photographers worldwide!
We are looking forward to you!
The Fuji X Forum Team
Register Close
