Fuji Flowers
dv.
A few hand-held shots taken with the Rokinon 100mm F2.8 lens.
Wild rose, blooming now - taken with X100S
Seen on a walk today...
X-E2 - 16-55 2.8 @ 55mm, F4, 1/320 Sek., ISO 200
"Tränendes Herz" (Weeping Heart?)
Regards Rieke
Peonies with X-T1 18-55mm
Regards Gert
Rosebud. Taken with Fuji X-T1 and 50-140mm lens
