Fuji Flowers
dv.
tilt
Fuji XT1 and 50-200mm
Fuji XT2 and 50-140mm shot at 140mm
Pinata Rose
Ex2 with 35 mm F1.4
EX2 with 35mm F1.4
Funny coincidence, I've made photographs of the same flower you can see a couple pages back: Lysimachia
The first one with XT-1 and  50-140mm+1,4x+MCEX11mm @196mm f/8, the second with 16-55mm f/2,8 @55mm f/5,6
http://<a data-flickr-embed="true" href="
" title="_DSF2613"><img src="https://farm5.staticflickr.com/4187/34094399282_a500e8d4c2_b.jpg" width="1024" height="683" alt="_DSF2613"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Edited by MrX100F
