Mushrooms
gvadf
Photo taken with X-T20, Samyang 12/2,0, Nissin i40 unleashed
Taken near Eibsee Lake, in the German Alps :)
X-T1 and 14mm at f/2.8
Edited by konzy
  • 11 months later...
  • 7 months later...
  • 2 years later...
X-T20; K&F concept adapter + Tokina AT-X Pro 100mm f/2.8 Macro; 1/2; f/11; ISO100, tripod; natural sunbeam lasted 3 minutes...
X-T20; K&F concept adapter + m42/m39 adapter + Leica Ernst Leitz Wetzlar 9cm f/4.0 Elmar; 1/15; f/8; ISO200; tripod; additional light from above MANFROTO Lumimuse LED3
X-T20; K&F concept adapter PRO + Meyer Gorlitz Primoplan 58mm f/1.9; 1/500 f/2, ISO200, tripod; additional light MANFROTO Lumimuse LED3 (front) + BLACK DIAMOND Astro 250 (backlight)
    • I used this for the latest firmware no problems. https://fujifilm-x.com/en-gb/support/download/firmware/cameras/x-t2/
    • I was just about to point that out, in my defense.
