Fuji remote app
miguel
Like many of us I would like to see some major refinements to the app.
In its basic form it is a good idea.
A Histogram would be a good start to improving this app.
I have been trying to get it to bracket exposures to no avail, anyone got any ideas?
I have just discovered that you can not send an image from the cameras sd card to your Camera Roll unless it was created by the remote app.
Existing images on your card can not be transmitted.
If this is correct, the app just got worse in my opinion.
Having taken some pics of family, friends or model, I had intended to use it to send an image from the sd card quickly to their email account.
What are other photographer doing?
