long travel combo advice - xt10 or xt1?
Interesting post, as I am getting through the exact same questions!
I have a slightly smaller budget than you, but I already have a X100s. The problem is that for travel it's not always enough: the fix lens is excellent, but the lack of zoom is often an issue when pressed by time...
So far I've decided to go for the X-T1 with the 18-135, to have the maximum flexibility, including when needing WR.
The X100s covers the 23mm focal. The TCL converter on the X100s could cover the 35mm focal (although I'll probably fall for the wonderful 35mm f1.4 one day).
Then it's about the ultra-wide side: on this I'm still hesitating between the 10-24mm and the 14mm... I may choose to rent them to decide. Why are you looking at the 12mm rather than Fujinon options? Price?
Anyway, the two bodies is certainly a good piece of advice (as many stated above) and you should probably look at the X100s as it's getting cheaper and cheaper second hand since the release of the X100T.
I'll make my decision within the next two weeks, but please keep us posted on what you decide after all!
Cheers
... you should probably look at the X100s as it's getting cheaper and cheaper second hand since the release of the X100T.
In a way I agree with you but on the other hand I think the combination of X-T1 and X100S will get you very frustrated with the latter. The X100S has many really annoying quirks which have been ironed out in the later cameras and the AF of the X-T1 is just years ahead of what the X100S manages. I'd advise anyone to instead get an X-T10 or at least X-E2. Also if the main camera breaks you'll still be able to use the 18-135 which will probably be your workhorse lens while travelling.
I'd rent the 18-135 and see if you like it. Personally I'd rather have the 16-55 2.8 WR since it's considerably sharper, brighter and overall a much higher quality lens. That extra 2mm at the wide end is nice as well. The 18-135 has an annoying feature that the zoom gets sticky as you move past 100mm to 135mm which makes it less enjoyable to use and I'm finding it's not a super sharp lens. The 16-55 is the best lens I have for my X-T1 and I have 6 or 7 of them.
The 18-55 2.8-4.0 is a fantastic lens. Has IS, nice image quality and is small (something to consider if you're on a bike). The fact is isn't weather sealed may seem to be a problem but if you look at my other posts you'll see I complain about WR on the X-T1 (worth getting but don't count on it).
I agree with others about the 2nd body. I lost a body to rain while in Rome. Got VERY lucky to be able to pick up a replacement 3 days later in Sicily after hunting around for two days. Those 3 days I shot with my x100s and it was a bit frustrating. The X-T1 body is small and light and easy to pack, just a matter of $. Just remember that you may end up losing both the lens and body so have a backup for both (why I like the 18-55 even more). Now if you'll be near camera stores all the time then pass on it but SE Asia and some parts of AU could be an issue. Hopefully you have an iPhone as your backup anyway (moment lenses are nice - momentlens.co). I use one for geotagging so have it with me always anyway.
If you want a wide lens I'd think about Samyang to save money. It's nice having something wide (12mm would be my choice) for landscape and even some in-town atmosphere pics. My 8mm is amazingly sharp so maybe the 12mm is as well. Annoying you have to focus by hand and no lens data transmitted to camera but for wide angle that isn't as critical (IMO)
    • Hello. Thankyou,now Is all more clear: I have take some time in you link. Let tell you.i was totaly forget this machine have "compress picture option" and not Only "compress lossless" anyway not change the experiment. RAW  and this last two format look like same result about Number of recording picture. Can tell alll results in this: in raw you can make 17 pictures for second.Is wrong.Is about One single Press and wait buffer. Full 30/20/10/8 not change. After 17 Need Press again. You not can Press before "redgreen light recording Is on"   With preshot you can have 25  are more 7 pictures  The story change Only in jpg shot only. In jpg at 30 you have 30 picture but redgreen light off very Fast so you can shot very quicly. At 20 shot Is about start look like infinite shot. 60   So the best performance are this last One  about Speed and recording picture after camera working witout big limit I want take a shot about Italy cyclet Just for passion. I think i Will use this last setting.  After Need check when battery not are full change and ambient temp.  Anyway my cam look like exactly specific about you link. Im Happy my cam working perfectly
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
    • Not sure how to delete threads, but I figured out what was wrong. In short, I was partially misunderstanding the view-mode's function. Also, the "+LCD Image Display" part requires that you have the Image Disp. setting set to anything but Off. Then it will display your last image on the LCD. If it's off, it's behavior will be exactly like the plain Eye Sensor setting.
