A Bevy of Beauties!
Mike G
Went to the WEX London Lens show on Saturday and on the Fuji stand were these!
Johan's, I was surprised at the GFX weight or lack of, in the hand the GFX feels only slightly larger than an X-T2 and the feel is also very similar to an X-T2. The small LCD panel seems superfluous to me, but I may be missing something! Something else I noticed was that the SS &a ISO dials are dished!
I was quite impressed but not by the cost!
Edited by Mike G
