L-Bracket without Handgrip
I used to have the Fuji quick release plate (or, as they called it "Small Handgrip" for the X-T1) because I did not require an additional grip. In my opinion, it wasn't needed and it looked goofy. However, to my dismay, I found out that Fuji discontinued this plate and is now only producing the hand grip plate for the X-T2. So I began researching my options from other manufacturers. I ordered a thirty dollar one from Ebay, but it was clunky and heavy. It also didn't really fit properly. But then I found the perfect one for my needs, also on Ebay. It's the PEIPRO L-bracket. I took off the small side bracket and just use the bottom. The plate is super-light and although it's so light has a smooth, closed bottom (only one opening for the battery compartment). I really don't know how they were able to make it so light.
So just in case you want a good looking, light arca-swiss compatible quick release plate that can stay permanently installed on your X-T2, you can't go wrong with this one. I highly recommend it.
Edited by karinatwork
Thanks for sharing. I'm always on the lookout for a good L-bracket. I have the Fittest brand--perhaps what you first tried--and it works, but doesn't fit well. I think I read somewhere that the Fittest is 128 grams and the PEIPRO is 71 grams. I wouldn't mind a slimmer, lighter bracket  :)
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
