Lens choice
Kev Andy
It is a tough choice. I recently had to make the same decision and I went with the 10-24, which is a very nice lens. I don't know if that helps, but the 10-24 is very sharp and easy to work with. The 16mm is quite a bit faster, if that makes a difference. They are both fairly heavy, so that isn't very different.
The ability to adjust the focal length was a key feature for me.
Good luck on your decision. I think either will be a good serviceable lens.
I'd recommend using the Fuji X comparison tool to compare FOV
http://fujifilmxmount.com/comparison/en/test-our-lenses/
If it is for landscapes, and I expect you'll be shooting at F/8 or higher, the F/1.4 of the XF16 wont make a difference, just a case of is the extra 2mm on the wide end worth it considering you already have the excellent 18-55.
the 10-24 gives you much more width.
You may want to consider the Samyang 12mm F/2, although i've not used it, I've heard nothing but good things about it
Edited by Tikcus
I tend to use to 10-24 more often for landscape/seascape due to the additional width. The F/4 with the OIS makes it possible to use it hand held until the second sunset. 16 mm isn't really that wide, but the F/1.4 makes it better for general photography especially in dark situations or for bokeh. It's good for close ups as well. Non of them would be a bad choice.
At least this is my experience from using these two lenses so far.
https://www.flickr.com/photos/leifbr/
I believe the 16 1.4 gives way more options, before being smaller and lighter than the 10-24 F4.  Also, keep in mind the 10-24 F4 is not water resistant; where the 16 1.4 is.
I have found the 16 to be extremely versatile - from near macro capability, to amazing wide-angle.  I've used it for wider portraits as well.
I looked at the 16 1.4 vs the 10-24 and I opted for the somewhat lighter, and I believe sharper 16, though the 10-24 sure provides a lot more options and versatility.
I have both 16mm and 10-24mm. Both lenses are sharp and optically excellent.
I use 16mm in tough lighting conditions because of its bright aperture. I have used it to photograph the night sky and stars.
With that being said, 10-24mm is my first choice for landscapes, travel and everything else. 10mm view of this lens turns even boring pictures into something special. 16mm can't do that...
I am in love with ultra-wides and even got a fisheye, which is the ultimate fun lens.
    • Looking for input; there are some decent deals and might want to take advantage to expand my lenses for my 100s already own: 110/2 32-64 35-70 100-200 + TC   Shooting mostly family shots, bringing my kit to capture family outings indoors and out. Tracking the 63/43 effective FLs on the two, but has anybody used both? Would the 55 (covered by two zooms right now) be redundant? Would the 80 be too similar in character to my 110 for portraiture?
    • See what I mean? Two instantaneous ads. Worthless.
    • What's the deal Fuji X Forum? I'm noticing there are seldom replies to any topics - except for advertisements posted as replies. Really lame. Anyone else noticing the only reply they receive to a question is an advert?  🤠 fotomatt in Colorado
