Iridient Digital
I have been using Iridient Digital as my main processor for probably 10 years now.  It is for Mac only so the PC people are out of luck on it.
He's a one man show, Brian, but he knows more about RAW files than I bet everybody out there including T Knolls.
He's also put in a lot of work on the X-Trans conversions including emulation styles.
Check it out.
http://www.iridientdigital.com/
  • 11 months later...
