Clicky
Issues with Yongnuo YN560-TX Triggers
Flash Yongnuo Trigger
  • Please log in to reply
16 replies to this topic
#1 arch_202
arch_202
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 16 February 2017 - 05:07 PM
Advertisement (Gone after free registration)
This month I decided to make an investment in a Yongnuo flash system based on high praise from this forum and others. I have 2 YN560 IV flashes, and a YN560-tx trigger, all in the cannon version and in use on my xt-1.
Flashes fire fine while mounted directly to the hot shoe, and connect and can be fired from the 560-tx while mounted to my xt-1. But the flashes will only fire once from the tx. I'll fire the shutter and the tx will pop both connected flashes, wait a few seconds (adjust the model, the lights, ect), and then try and fire a second shot, but the flashes won't pop. The blue LED lights up fine on both flashes, as if the tx is still connected appropriately. They will only fire again once I adjust a power/zoom/group setting on the tx trigger. I've gotten into the habit of just bumping the power up then down on the tx before each shot, just to get the flashes to fire. But this poses a problem when I need to take multiple shots quickly, or if (as is the case when I have no model...) i'm taking self-portraits and am operating from the fuji camera remote app.
I then tried operating the flashes in trx mode, firing with one flash on the camera and one off. Same thing. The flashes will fire once from camera release no problem, but will not fire again until I adjust a setting on either flash. Optical slave mode fires consecutive flashes no problem, and the pilot button works consecutively no problem as well. My suspicion is that they're wating for a half-press wake up signal from the tx before each flash release, but since I'm operating from a fuji camera, the wake-up signal on half-press is not supported, and it doesn't send it.
I've scoured the forums and tutorials around the web to see if i'm doing something wrong. I've set what I think are the appropriate settings (same channel and groups on all connected flashes/trigger, flashes in rx mode, single flash, camera not in silent mode, manual shutter, single shot, live-view off). I even ordered a second trigger, but when that arrived yesterday and operated exactly the same way, I reached a particular level of despair. I'm considering returning it all and abandoning off-camera flashes for the time being.
Any and all help is welcome and appreciated. Thanks!
#2 JacksonXNY
JacksonXNY
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 28 March 2017 - 12:17 AM
Im surprised this post has been up this long with no Reply. Im Actually experiencing the same problem and i cant seem to diagnose the issue. Did you get it solved?
#3 arch_202
arch_202
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 29 March 2017 - 06:54 PM
In fact I did not.
I contacted a yongnuo retailer, and he said he had never encountered this problem before. Since then I've tried updating the camera's firmware since there were a lot of improvements to the flash menu, but still no luck. I had already passed the deadline for returns, so i'm stuck with them i'm afraid :/
Let me know if you figure any of it out!
#4 Adam Woodhouse
Adam Woodhouse
    Advanced Member
  • Members
  • PipPipPip
  • 371 posts
  • LocationOntario, Canada
Posted 31 March 2017 - 09:33 PM
That sounds really odd.  I have the Nikon version (which I don't think it matters as it just uses the center pin to fire) and have the Tx on the camera and the flashes off to the side on a small light stand.  I can shoot away and each time the flash will fire fine (as long as it has time to recharge).  It was that way when I had them on my Nikon bodies, and the same works for my XT1 and XT2.
Camera body is mechanical shutter only.  Make sure you are not using either electronic shutter or MS+ES.  I think I remember someone commenting once that if ES is enabled at all, flash can be a problem.
TWO Fujifilm X-T2's
16mm/1.4 | 35mm/1.4 | 10-24mm/4 | 16-55mm/2.8 | 50-140/2.8
Rokinon 8mm/2.8
Flashes: Fujifilm EF-X500, iNissin i40 and two Yongnou 565's
Classic Lens Adapters: M42, Canon FD, Nikon and Minolta MD
Adam Woodhouse, Wedding Photographer
Ontario, Canada
http://www.adamwoodhouse.info
Twitter: @woodhousephoto
#5 JacksonXNY
JacksonXNY
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 06 April 2017 - 11:29 PM
In fact I did not.
UNREAL.... IDK what in the world is going on. the only thing that just came to my head is that it may be the type of battery just mayyyyybe the issue but i gotta try it and see... this sucks because it works flawlessly with my X100S.. how the X-PRO2 being a better and Pro level Fuji X system not work with the same flashes.. that makes me scratch my head hardcore and its very frustrating..
#6 arch_202
arch_202
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 06 April 2017 - 11:46 PM
Same. I tried changing my batteries with more expensive ones, but still no luck. I had originally thought that the flashes/trigger were waiting for an additional signal from the camera on half-press. I had heard that was an unsupported feature on fuji cameras, but I haven't found a way to test that theory. It also would make less sense if you've operated these successfully on another fuji camera..... But still. I can't find any features/settings on the flashes that adjust the signals that they receive. The only thing remotely close is the transceiver modes, but changing those just causes them all to stop working completely. It seems to only be a problem when they are connected wirelessly. Slave mode works fine.
My computer engineer roommate has tossed out the possibility of signal interference, and i'll admit that I don't have the knowledge to check him on that, but it seems to me like if there was interference they wouldn't be firing at all.
¯\_(ツ)_/¯
That's all I got.
#7 JacksonXNY
JacksonXNY
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 07 April 2017 - 03:08 PM
¯\_(ツ)_/¯
That's all I got.
I got and reply in message on Reddit from a fellow with the same issue. He stated he changed either the Flashes or the Transmitter. he did not specify but replied to ask if it was the TX or the flashes. I'm putting my money on the TX because i don't understand how i get 2 NEW flashes from the box and and they both behave the same... so i would think that we Should replace the TX and hopefully thats the issue... I would love to think that it would be because there little to no information about this problem online.. so i feel almost very alone on this issue...
#8 JacksonXNY
JacksonXNY
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 07 April 2017 - 03:15 PM
WOOOOOAH... I was Wrong.. the person replied and said he exchanged the TX 3 times and still had the issue. he said it was the Flash UNIT..... so my fellow people... exchange the dam FLASH unit until it works with your X-Pro2 X-PRO 2 or X-T2...
Cheers..
#9 marcuskaz
marcuskaz
    Newbie
  • Members
  • Pip
  • 1 posts
  • LocationSan Francisco, CA
Posted 26 April 2017 - 06:51 PM
I'm having the same issue with my X-Pro2 and the Yongnuo 560TX triggering a Yongnuo 560IV flash.
My non-optimal work around is to adjust something on the transmitter in-between each shot, if I just change the power up and then down again and then it will fire the flash. The next shot I have to make some adjustment again for it to fire, otherwise it doesn't. It seems to be something needs to keep the two units awake.
#10 Danimal
Danimal
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 12 May 2017 - 04:38 AM
I'm adding a +1 on this issue.
I'm using and XT-1 with the same TX + 2 560IV units. Mine has a slight variation of issue in that the flash(es) will trigger and fire great for quite a while and then all of the sudden they stop firing on shutter release. However, when I press the test button on the TX they DO fire. Odd. So it's not the TX to 560IV communication it would seem nor the flashes. So I'm going to put out the idea that there is something going on with the signal that the fuji is sending to the TX. Does this idea jog someone's imagination?
When they do work I'm loving them...but have to figure out a way to get them consistent....they stop a shoot in it's tracks when they do this.
Also I'll have to try to the power up then down idea tomorrow.....didn't think of that today or Tuesday when this happened.
Happy shooting
Dan
#11 kmeinhold
kmeinhold
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 05 August 2017 - 10:13 PM
I have the YN560TX, YN560III, and YN560IV.
The YN560III fires every time, the YN560IV only fires once.  The only work around I found is to make an adjustment on the remote to get it to flash again.
PS:  Not a Fuji user (have the Sony a6000), so it seems not the camera but flash related and specific to the YN560IV.
Keith Meinhold
keithmeinhold.com
#12 jkmnop
jkmnop
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 30 August 2017 - 04:49 AM
Odd. I'm having exactly the problem you're describing with the YN560-TX on my Sony a7rii. It flashes once and then some sort of adjustment has to be made on the trigger before it will flash again. The blue light flashes indicating a signal has been received but no flash. That being said the setup works perfectly on my X-T2.
#13 jkmnop
jkmnop
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 30 August 2017 - 04:50 AM
...also, I have multiple YN-560IV flash units and the behavior is the same with all of them. The all work perfectly with my X-T2 and Canon 6D bodies and all fail as you all have described with the Sony.
#14 dfaye
dfaye
    Advanced Member
  • Members
  • PipPipPip
  • 71 posts
Posted 30 August 2017 - 12:54 PM
I find it simpler to keep the 560-TX off-camera to control the flash settings, and put an RF-603 trigger on the camera to trigger the flash. This way, it's much easier - especially in low light - to adjust the flash settings on the 560-TX, and the RF-603 is much less cumbersome in the hotshoe. This should eliminate the problems described above, and a set of RF-603 triggers is fairly cheap. Just a thought.
#15 shooter
shooter
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 06 September 2017 - 03:49 AM
I signed up just to make this comment because it is driving me mad.  The same thing is happening to me with a Panasonic G7.  The 560IV fires with the first shot.  Second shot- nothing.  The blue light flashes, but no trigger. If I touch any adjustment on the 560TX then the next shot will fire, and then it's back to square one.  It's happening on Fujis and Sonys and Pannies, and it's happening with the 560IV.  I have a shoot for a commercial property in a week.  So, I guess my options are to go for a cactus trigger set or a cheaper set of 603's, or take a chance and buy a new 560IV and do some kind of ritual dance...  I can't take the chance at this point anymore and there doesn't seem to be an answer to this problem.  I guess it's just a glitch in the software somewhere.  Right now I don't care about remotely controlling the settings on my 560IV as much as I need the thing to flash without my having to walk all the way back to the camera every time and look like a moron to my clients.  It's just for single room shots and some window pulls.  I'm gonna try the different trigger (603/cactus) option and return the 560tx.  Bummer.  What a great concept.  Maybe they're intended to work all the way with only Nikon and Canon?  SMH
#16 recasper
recasper
    Newbie
  • Members
  • Pip
  • 2 posts
  • LocationAlameda, CA
Posted 13 October 2017 - 01:32 AM
To further kick the can down the road, I might as well add my name to the list.
Received my brand new, bagged and boxed 560TX with two 560IV's today... Hooked em up, synced em up, pop... and then nothing.
Same as everyone else here... I can reengage them after the first pop, by flipping the power setting back and forth... pop, then nothing... flip back and forth, pop, then nothing... So, reading a previous response above that Yongnuo customer support was "not aware" of this, tells me they are either aloof, or ignoring the reports...
This seems to be an issue that goes beyond a couple of faulty units. Whether it's a massive batch problem, or something that we have not yet discovered, seems to me this would be something that is escalating and should be addressed. Fingers crossed.
Edited by recasper, 13 October 2017 - 01:33 AM.
#17 RileyLewis
RileyLewis
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 16 October 2017 - 04:02 AM
I just signed up to add my name to this list, except I am using a Canon 5D mk iii.
I have one YN560 IV on-camera (in TX mode, acting as master), and two more off-camera in RX mode. I have factory-reset them multiple times and tried all manner of settings, but no matter what I do they will only fire once, unless I change a setting. This won't work for me, as I need them for weddings and won't have time to change something each time.
I will be contacting Amazon to see if I can return one of the flashes for a TX instead to see if that fixes it. Actually, maybe I will first try using each of the three flashes as the TX to see if that makes a difference.
Just wanted to let you guys know that it's not just Fuji cameras having this issue, it can affect Canons as well.
Also tagged with one or more of these keywords: Flash, Yongnuo, Trigger
x
Registration is free
Not registered? Really?
Discover the full potential of the Fuji X Forum... register now!
Registration is free and done in a few minutes!
As registered member you can discuss, post your questions and present your images.
And get in contact with Fuji X photographers worldwide!
We are looking forward to you!
The Fuji X Forum Team
Register Close
