Leopard Botswana
Mike K
X-Pro2 & XF 18-55mm
Found him high up in a tree at sunset.
X-Pro2 & 300mm f2.8  Carl Zeiss Apo Tele Tessar
Close up...
    • I used this for the latest firmware no problems. https://fujifilm-x.com/en-gb/support/download/firmware/cameras/x-t2/
    • I was just about to point that out, in my defense.
