Clicky
XF 50-140mm
  • Please log in to reply
8 replies to this topic
#1 ron.wightman
ron.wightman
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 11 January 2017 - 04:46 AM
Advertisement (Gone after free registration)
XF 50-140 f2.8 - One of my fav go to lenses. Always sharp, clear and beautiful. The lens hood has always been a tight fit. Does not bayonet smoothly and snap in place like the others. Is it just the particular lense I have? Anyone else have the same experience?
#2 nullawally
nullawally
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 11 January 2017 - 10:57 AM
Same here. Thought I cross-threaded It. Had the same problem with the old Canon 17-40mm. As you say, beautiful lens, but the lens hood frustrates the hell out of me
#3 erwiurewurwehu
erwiurewurwehu
    Advanced Member
  • Members
  • PipPipPip
  • 158 posts
Posted 11 January 2017 - 05:26 PM
Same here. Fuji is really good at building lenses but their hoods and caps are just pain terrible. When I had Pentax, all the hoods just snapped on perfectly. Never had any problem. Not so with Fuji.
#4 ron.wightman
ron.wightman
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 12 January 2017 - 03:57 AM
Well it makes me feel better knowing I'm not alone - thanks for the reply
  • Puck likes this
#5 pez
pez
    Advanced Member
  • Members
  • PipPipPip
  • 46 posts
Posted 12 January 2017 - 08:15 AM
Yip mine is tight as well. Only suggestion is to very gently trim  ie with watch makers file or very fine wet and dry paper.  Using a powerful magnifier look for the area were there is clear rubbing. Little test little and test is the rule.  At very worst it is replaceable.
#6 EddieX
EddieX
    Advanced Member
  • Members
  • PipPipPip
  • 85 posts
Posted 12 January 2017 - 07:01 PM
Funny, mine is loose, very easy to rotate it.  Want to trade? :D
2x X-T2/VPB | 16 ƒ1.4 | 35 ƒ1.4 | 90 ƒ2 | 18-55 ƒ2.8-4 | XF 16-55mm ƒ2.8 | XF 50-140 ƒ2.8 Mitakon 35mm ƒ0.95 | RRS |
want: XF 8-16mm ƒ2.8
#7 Tom H.
Tom H.
    Advanced Member
  • Members
  • PipPipPip
  • 654 posts
  • LocationBelgium
Posted 13 January 2017 - 12:42 PM
Mine was annoyingly rigid at first, but after use it has become just "tight", which I like because I tend to leave it in my workbag for days on end without having to check if it came off.
#8 MSW
MSW
    Advanced Member
  • Members
  • PipPipPip
  • 100 posts
Posted 18 January 2017 - 05:06 AM
I'm not real excited about any of the lens hoods (or front and rear caps) that Fuji makes.  I'm comparing them to the Nikon equivalent to which I had been accustomed.  Every brand has some special area of weakness and this is Fuji's.  Not a reason to abandon the rest of the system but it is an area of constant annoyance.
[At least in the case of front lens caps, when a replacement is needed a Nikon of the same size is a definite improvement.]
#9 Adam Woodhouse
Adam Woodhouse
    Advanced Member
  • Members
  • PipPipPip
  • 378 posts
  • LocationOntario, Canada
Posted 02 February 2017 - 02:18 PM
Yup, same issue on mine.  I thought something was wrong when I first got the lens because it felt like I was cross-threading it when I put it on.  But over time, it has gotten a bit better.
TWO Fujifilm X-T2's + ONE X-Pro1
16mm/1.4 | 35mm/1.4 | 10-24mm/4 | 16-55mm/2.8 | 50-140/2.8
Rokinon 8mm/2.8
Flashes: Fujifilm EF-X500, iNissin i40 and two Yongnou 565's
Classic Lens Adapters: M42, Canon FD, Nikon and Minolta MD
Adam Woodhouse
Ontario, Canada
http://www.adamwoodhouse.info
x
Registration is free
Not registered? Really?
Discover the full potential of the Fuji X Forum... register now!
Registration is free and done in a few minutes!
As registered member you can discuss, post your questions and present your images.
And get in contact with Fuji X photographers worldwide!
We are looking forward to you!
The Fuji X Forum Team
Register Close
